Coolant problems OH MY HELP
Old Feb 13, 2006 | 07:56 PM
lsegcoupe's Avatar
Default Coolant problems OH MY HELP
Second time i posted about this and i find it hard to believe it is my head gasket but anyways...here it is
Majority of the time it runs fine...Sometimes are a long drive or a couple of hard races i notice my temp gauge at hot...Valve cover isnt hot like it would be if it was overheating and the coolant isnt hot enough to burn you...
Anyways when it gets hot like that i pop the hood and notice moisture from coolant by the overflow tank...no where else...i havent noticed any puddles or drips from anywhere besides the overflow tank lid when it does this...but the lid is very tight...any ideas?
Old Feb 13, 2006 | 08:45 PM
RTI's Avatar
RTI
Default Re: Coolant problems OH MY HELP (vtecisneeded)
It is normal for the overflow tank to fill when the engine gets hot. I would make sure your radiator cap is good, it may be bleeding off pressure too soon. If the car gets hot after hard racing you may just not have enough cooling capacity. Is your radiator old? Also, is your car automatic?
Old Feb 13, 2006 | 10:01 PM
old man neri's Avatar
how old is your coolant? Is it the right mix?
Old Feb 14, 2006 | 07:27 PM
lsegcoupe's Avatar
Default Re: Coolant problems OH MY HELP (old man neri)
Yes it is the right mix and if i am leaking coolant when i race...it is probably new coolant right?...Yes i believe i said i have to refill it...and it is not filling my coolant tank at all...The moisture is over the OVERFLOW TANK not the actual radiator...
JBBNJ609
Honda Civic (2001 - 2005)
Jun 29, 2012 11:07 AM
GotToyota
Nov 24, 2008 10:18 PM
hondalove888
Jun 9, 2008 06:22 PM
mitchc05
12
Aug 19, 2007 04:15 PM
redwinqs
15
Jun 14, 2004 03:39 PM
