Autometer Tach with no instructions. How do I install this thing?
Old Mar 26, 2002 | 07:25 PM
D1ANCER's Avatar
Default Autometer Tach with no instructions. How do I install this thing?
I just got an Autometer tach w/ shift light, but it has no instructions. I was wondering if anyone new how to install this in a 94 civic B16A. If so, could you please help me out.
Old Mar 27, 2002 | 08:15 AM
salbaje's Avatar
Default Re: Autometer Tach with no instructions. How do I install this thing? (D1ANCER)
ok there are 4 wires on the tach
black is for ground
red is for power ignition lead
white is for the light when you turn on your lights
green goes to distributor
Old Mar 27, 2002 | 09:24 AM
D1ANCER's Avatar
Default Re: Autometer Tach with no instructions. How do I install this thing? (salbaje)
Sorry, but I am no electrician and I don't understand how to do it with what you just wrote. Is there anyway to get a real instruction manual or a diagram of some sort?
Old Mar 27, 2002 | 09:35 AM
coquinn's Avatar
Black wire is a ground wire.
Red wire is for ignition lead -or- 12V constant.
White wire is for lighting at night.
Green wire goes to your distributor.
Even if you do get instructions, they're going to tell you to do the exact same thing. I believe the Autometer instructions are universal anyway ...so you won't get a car-specific diagram.
Old Mar 27, 2002 | 10:07 AM
D1ANCER's Avatar
Default Re: Autometer Tach with no instructions. How do I install this thing? (coquinn)
There are thses little connectors on the end of my wires, should I cut those and splice the wire to the other ones or what?
Old Apr 2, 2002 | 11:05 PM
lshybrid195's Avatar
ok green wire goes to ur distributor and connect it to the blue wire and for the red connect it to any source that has power and as for the white wire u have to look under the dash and there should be a white wire also and u connect that white wire from ur tach to that and as for the black jus ground it to a solid place i hope dis help u out it took me only 10 min to do mine it waz so easy
4gen4drcivic
10
Feb 2, 2009 09:23 AM
teddy_dc2
Mar 15, 2007 07:02 PM
EG type GTR
Jul 20, 2006 11:38 AM
PINKS
May 15, 2006 08:55 PM
hmonglonertim
May 9, 2002 02:25 PM
