lagging problem with acceleration
Old Feb 13, 2006 | 05:49 PM
fit256nj's Avatar
Default lagging problem with acceleration
sometimes when i accelerate, usually in first gear, my car lags on pickup really bad. i was told it was my fuel injectors, but after replacing them all and checking them from time to time, they seem fine, im guessing its my clutch but not sure, or maybe there is another way to check injectors that im not sure about. Any suggestions?
Old Feb 13, 2006 | 06:04 PM
SicilianSpeed42's Avatar
Default Re: lagging problem with acceleration (fit256nj)
your clutch would probably need to slip in order for it to be the cause, my guess is its fuel/spark related...try a tune up (cap/rotor/plugs/wires) also, when is the last time you changed the timing belt?
Old Feb 13, 2006 | 06:11 PM
ZipTieGUy's Avatar
its spark related, get a new ignition coil or replace the whole damn dizzy
Old Feb 13, 2006 | 06:20 PM
MikeD718's Avatar
Default Re: (ZipTieGuy)
if you get new plugs and wires make sure you get some NGK's not bosch.
Old Feb 13, 2006 | 06:21 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (MikeD718)
He's my friend. He got new plugs around the same time as the injectors. Not sure about plugs I'll take a look tomorrow
Old Feb 13, 2006 | 07:05 PM
ThaCivicAssassin's Avatar
Default Re: (SkoundrelUSA)
Get some injector cleaner on a empty tank.....Makes a big difference in the line not just the injectors and if not it's just good maitanance.........
Old Feb 13, 2006 | 07:26 PM
cute little bastard
Default Re: (ThaCivicAssassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaCivicAssassin &raquo;</TD></TR><TR><TD CLASS="quote">Get some injector cleaner on a empty tank.....Makes a big difference in the line not just the injectors and if not it's just good maitanance......... </TD></TR></TABLE>
Already done, didn't do anything lol
Old Feb 13, 2006 | 10:30 PM
crxsi8's Avatar
Check your coil system..mine had the same problem..let it idles..and if it seems like its missfiring then its your coil sys.
Old Feb 13, 2006 | 11:06 PM
coolikedat's Avatar
Default Re: (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">Check your coil system..mine had the same problem..let it idles..and if it seems like its missfiring then its your coil sys.</TD></TR></TABLE>
yeah, seems like a coil problem. if you already replaced the spark plugs, wires etc.. then my only guess would be the coil.
Old Feb 14, 2006 | 12:16 AM
xd69's Avatar
check your timing....
Old Feb 14, 2006 | 04:51 AM
G2 Speed's Avatar
Default Re: lagging problem with acceleration (xd69)
air filter....?
Old Feb 14, 2006 | 06:02 AM
IHateJDM's Avatar
Default Re: lagging problem with acceleration (G2 Speed)
low fuel pressure?
Old Feb 14, 2006 | 06:08 AM
cute little bastard
I'm pretty sure its not misfiring, but we'll probably do the coil system anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 &raquo;</TD></TR><TR><TD CLASS="quote">check your timing....</TD></TR></TABLE>
Yeah I'm looking into a timing light, just not sure which one I want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">air filter....?</TD></TR></TABLE>
Brand new...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">low fuel pressure?</TD></TR></TABLE>
I'll put my gauge on his today and see if its low. It should be at like 35-40ish with the hose right?
Old Feb 14, 2006 | 06:10 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
I'll put my gauge on his today and see if its low. It should be at like 35-40ish with the hose right?</TD></TR></TABLE>
what motor? if d16, its 35-42 wot (vacuum line removed from fpr).
Old Feb 14, 2006 | 06:13 AM
cute little bastard
Default Re: (IHateJDM)
what motor?</TD></TR></TABLE>
His, D16Z6
Old Feb 14, 2006 | 09:03 PM
ApolloSpeed's Avatar
you really put injector clean in an empty tank ????
Old Feb 15, 2006 | 05:04 AM
G2 Speed's Avatar
Default Re: (ApolloSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">you really put injector clean in an empty tank ????
that's what your suppoesed to do.... right before you fill up your tank with gas
Old Feb 15, 2006 | 07:47 AM
ck123's Avatar
oil in spark plugs
Old Feb 15, 2006 | 09:16 AM
Default Re: (G2 Speed)
i thought you meant only running injector clean....no gas, my bad
Old Feb 15, 2006 | 09:19 AM
hondafan62269's Avatar
Check the fuel pressure. Might need a new filter or the whole pump too.
NoLeftTurn
Jul 15, 2011 08:00 PM
949
12
May 12, 2008 07:30 AM
k20o2o4civic
Feb 6, 2008 12:18 AM
Hammer01
Feb 20, 2007 01:33 PM
whitecrx
May 9, 2005 05:28 PM
