**Help**, Looking for DIY link to make my "Si" emblem in the gauge cluster light up.....**
I searched a bunch of times here and ClubSi.com for the answer, But nothing came up.
I'm looking for the page that explains how to make your 99-00 Civic Si cluster Emblem to glow red at night.
I am not sure if there is a need to completely take apart the gauge cluster including needles, Or if there's an easier way.
Pics would help or maybe some of you can share your experiance with this mod
Thanks in advance
-Jeff
Thanks in advance
-Jeff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mulletov »</TD></TR><TR><TD CLASS="quote">http://www.jimmmmmmmah.com/Ins...w.htm
^ theres one. go nuts.</TD></TR></TABLE>
Thank You Thank You Thank You, You my friend deserve a gold star for the day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 »</TD></TR><TR><TD CLASS="quote">emblems glow red...seems strange. why would you want that
Mike</TD></TR></TABLE>
Because
Because
actually, u could tap into the ECU and make it light up only when VTEC engages. I think that'd be tight as hell! Im not trying to be sarcastic, i really thing that'd be sweet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">actually, u could tap into the ECU and make it light up only when VTEC engages. I think that'd be tight as hell! Im not trying to be sarcastic, i really thing that'd be sweet.</TD></TR></TABLE>
it cant do that, if you read the post in the link it just sands the black paint off the back so light shines through the SI logo. there is no light to wired up to vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">actually, u could tap into the ECU and make it light up only when VTEC engages. I think that'd be tight as hell! Im not trying to be sarcastic, i really thing that'd be sweet.</TD></TR></TABLE> actually sounds like a good idea, I could maybe wire up a Bright LED
i just did it to mine and it turned out great! took me 3 or 4 mins!!!
i had been looking into doing this but never got around to it!!!!! someone do a write up on how to do it with vtech engagement or shift point would also be koo!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91blksi »</TD></TR><TR><TD CLASS="quote">any nite shots?</TD></TR></TABLE>
+2
for realz i might have to do this to my si..
+2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic »</TD></TR><TR><TD CLASS="quote">do the have those for EG's?</TD></TR></TABLE>
Ummm, No!
Ummm, No!
there is a DIY that i saw a while ago about how to wire a light to when VTEC engages. Some del sol DIY website...dont have the link sry. its basically tapping into the ECU and running wires to an LED and grounding it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">there is a DIY that i saw a while ago about how to wire a light to when VTEC engages. Some del sol DIY website...dont have the link sry. its basically tapping into the ECU and running wires to an LED and grounding it. </TD></TR></TABLE>
They have that horn activator when VTEC is engaged as well so I suppose they run off the same ECU tap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMedEK »</TD></TR><TR><TD CLASS="quote">im ganna sand down the part of the rpm that is red ill post pics later!
ya i just did the si emblem and im hella happy how it stands out
post pics of yours with the red rpm!
Modified by EkSi at 1:37 PM 2/15/2006
</TD></TR></TABLE>ya i just did the si emblem and im hella happy how it stands out
post pics of yours with the red rpm!Modified by EkSi at 1:37 PM 2/15/2006
can someone seriously post a pic already i wana see that **** yoo and can someone find the DIY on how to make it grow when vtec engages
