WHY??????
I have a 92 civic, I recently replaced a bent exhaust valve. I still get bad fuel economy and car stutters to move when i give it gas.... would anyone have a conclusin on why this is happening???????????
Loose nut behind the wheel?
You should do compression and leakdown to check the condition of the motor, as well as inspect all of the normal things : spark plugs, distributor cap, plug wires, air filter, fuel filter, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan124 »</TD></TR><TR><TD CLASS="quote">I have a 92 civic, I recently replaced a bent exhaust valve. I still get bad fuel economy and car stutters to move when i give it gas.... would anyone have a conclusin on why this is happening???????????</TD></TR></TABLE>
How badly was the valve bent? I agree on a cylinder leakage test to start...
Did you have the valve and seat ground to fit, or just put it in? Did you check all of the valves for straigtness and proper seating (regrinding as necessary)? You replaced the headgasket and timing belt with new parts, right?
Channooo
Feb 3, 2010 02:47 AM
someguyudontknow
Nov 26, 2007 04:30 PM
