Possible to Change rod bolts with block in car??
Old Feb 13, 2006 | 07:12 AM
watsvtecEK's Avatar
Default Possible to Change rod bolts with block in car??
I was wondering if it was possible to drop the oil pan and change the rod bolts on a b18a. i was going to do a stock bottom end ls/vtec and then later build it up. But i want to just change the rod bolts because they are usually the first thing to fail. Is it possible?? is there enough room to do it properly?
Old Feb 13, 2006 | 07:39 AM
djtony5's Avatar
Default Re: Possible to Change rod bolts with block in car?? (D 2da A9)
Yes you can. Just be sure to have some sort of manual. If you want to remove the rod and stuff, you have to remove the head, drop the oil pan, push the piston out, loosen the main cap, take the piston to a machine shop and let them push out/in the new rod bolts, and depending on the condition of your cylinder wall you will either have to get it rehone or just slap that biotch back in without honing. G/l. Hope you have plenty of time around to do it lol. I did and everything work fine.
Old Feb 13, 2006 | 07:36 PM
watsvtecEK's Avatar
Default Re: Possible to Change rod bolts with block in car?? (djtony5)
never realy done any internal engine work but could i just change out the rod bolts w/o taking the rod and piston out? just take the stock bolt out and replace it with a arp. I just want to do that no other internal work. then later do a full rebuild with forged pistons/rods, ect..
Old Feb 14, 2006 | 10:13 AM
Sam92Teg's Avatar
Every time I see someone install ARP rod bolts, they have the large end of the rod resized. I have wondered if it is really necessary, but seems to be the common practice. Which would mean you would have to pull the rod and take it to a machine shop.
turbohatch96y7
Feb 11, 2015 09:14 PM
Corksil
12
Sep 19, 2012 11:49 AM
88Snatch
Jul 19, 2007 08:18 PM
dustrag
Dec 8, 2004 06:29 PM
willyboyK20
Mar 25, 2003 05:33 AM
