Oil pressure Problem EK9
Old Feb 13, 2006 | 06:47 AM
Buzz-manic-motorz.com's Avatar
Default Oil pressure Problem EK9
This site was recommended by a friend in Dublin, Ireland.
I heard you guys are masters when it comes to this type of thing.
I have a 96 Jap import civic SiR with a B16b engine swop.
Recently I have noticed the oil pressure has gotton very low. When Im in the vtec with foot to the floor, oil pressure doesnt even hit 2.8, and when idling, oil pressure is 0 So car is off the road till fixed.
I have ordered a new sump set, oil pump from Honda japan, and will be here in approx 3 weeks... But what else will I need> I found the oil breather box was leaking, so have one of them as well. If this doesnt fix the problem, Im screwed and possible looking at a bottom end rebuild.. The bottom block is off a DC2 Integra type-r (jap).
Any suggestion is very welcome. Car is running 193.4bhp and 149.8lbs torque.. Dont wanna loose the torque, as a 1.6 is Very good So I really dont want anyone near the bottom end, my secret will be out lol
Thanks and cheers in advance,
Buzz.
Old Feb 13, 2006 | 07:27 AM
Cuda70's Avatar
Default Re: Oil pressure Problem EK9 (Buzz-manic-motorz.com)
Oil pressure is developed at the main bearings.
Check your clearances.
Most (99%) of the time your problem, as describd, will be main beaaring clearance.
I know that's not what you want to hear, but it is the truth.
Good luck!
Old Feb 13, 2006 | 08:17 AM
So basically rebuild it to be on the safe side?
Old Feb 14, 2006 | 03:54 AM
should I do teh rebuild anyway?
Bump?
Old Feb 15, 2006 | 02:46 PM
d16dcoe45's Avatar
There was no need to get a new pan and sump--like stated previously it seems like its time for a rebuild before you spin a bearing and ruin the crank.
Mike95lude
12
Dec 21, 2010 01:59 PM
imptricer
Jun 10, 2007 11:10 PM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
boost'dsiR
Jul 20, 2005 02:44 PM
EG*MonKEY
Nov 11, 2002 09:57 PM
