motor rebuilding...
Old Feb 13, 2006 | 05:25 AM
rice a roni's Avatar
Default motor rebuilding...
if you can still see the hatch marks from factory and there is no ridge on top of the cylinder, is it neccesary to hone the cylinders?
Old Feb 13, 2006 | 08:08 PM
mahatma's Avatar
Default Re: motor rebuilding... (0mghi2u2)
I guess it's not necessary. Have you used a T-gauge and checked the measurements all the way down the cylinder to see that they're true?
Check each cylinder in like 5 or 6 spots from top to bottom. Not sure what kind of variance is "out of spec" though.....
My machinist found there was 4 thousandths variance in a couple cylinders so he recommended we bore.
Old Feb 13, 2006 | 08:27 PM
blah13's Avatar
Default Re: motor rebuilding... (mahatma)
I'm assuming this motor has some miles on it, and I'd also assume your going to use new rings when you rebuild, so in this case, yes. Re-hone.
Old Feb 14, 2006 | 08:17 AM
Default Re: motor rebuilding... (blah13)
alright, just checking cause im lazy, but i guess i should do it right the first time...
Buffs8080
Honda Civic (2001 - 2005)
Jan 20, 2014 06:52 AM
downeyballz
Jul 6, 2008 01:21 PM
turbotime
Nov 2, 2006 11:06 AM
NA JDM GSR
Oct 9, 2006 07:04 PM
JFG Kevin
Sep 8, 2006 07:27 PM
