HOW DO YOU CHANGE AXLES??
ok
tools 22 mm socket
breaker bar
17mm socket
crowbar/prybar
grease etc
ok first of all make sure its in n/neutral
take the tire off/break the lugs loose
jack up the car or the side u are changing
unbolt the forks of the suspsion pull it out
unbolt the balljoint its easier to do that way uhh my way
take a flathead screw knock out the nut which u should see
break the axel nut off hit it with a rubber hammer then pull the brake/susp towards u and go under the car and pop out the axel
if u have any ? just im me
tools 22 mm socket
breaker bar
17mm socket
crowbar/prybar
grease etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">tools 22 mm socket </TD></TR></TABLE>
I think it is supposed to be a 32mm for the axel nut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogbiscuit »</TD></TR><TR><TD CLASS="quote">search there is a really good thread on here with pics and everything it was an install done in a shop. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip King »</TD></TR><TR><TD CLASS="quote">Tutorial:
https://honda-tech.com/zerothread?id=382416</TD></TR></TABLE>
FIRST YOU PUT IT IN REVERSE BECAUSE YOUR TRANNY WILL POP OUT THE AXLE EASIER AND THEN YOU SPRAY MAYONAISE ON THE SPINDLE TO MAKE IT POP OUTI. USE A PRY BAR AND STICK IT IN PLACE OF THE AXLE AND TURN ON YOUR CAR AND DRIVE AROUND FOR 3 HOURS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 »</TD></TR><TR><TD CLASS="quote">FIRST YOU PUT IT IN REVERSE BECAUSE YOUR TRANNY WILL POP OUT THE AXLE EASIER AND THEN YOU SPRAY MAYONAISE ON THE SPINDLE TO MAKE IT POP OUTI. USE A PRY BAR AND STICK IT IN PLACE OF THE AXLE AND TURN ON YOUR CAR AND DRIVE AROUND FOR 3 HOURS
Theres no reason for sarcasm, this is a legitimate question that needed a legitimate answer, just cuz your dumb enough to do that doesn't mean he is.
</TD></TR></TABLE>Theres no reason for sarcasm, this is a legitimate question that needed a legitimate answer, just cuz your dumb enough to do that doesn't mean he is.
Was that supposed to be funny?
</TD></TR></TABLE>Was that supposed to be funny?
drewbie
Jun 4, 2005 09:53 AM
mongoliandonuts
30
Feb 15, 2004 09:51 AM
