Need some info on brake swap for my 92 civic
Old Feb 12, 2006 | 11:46 PM
truevietluv636's Avatar
Default Need some info on brake swap for my 92 civic
i got a 92 civic hatchback vx and wanted to upgrade my brakes. dont have much cash so im looking into doing a full swap from a 94+ integra. front and rear. Could someone give me a full list of parts i might need from an integra w/o abs.
so far i got these things but need the year and model of the car its from.
master cylinder
propotional valve
calipers
brake lines
upper and lower control arms
Old Feb 13, 2006 | 12:21 AM
BlueIntegraBoy's Avatar
Default Re: Need some info on brake swap for my 92 civic (truevietluv636)
You can get the brakes from an Integra with ABS if you wanted.
Parts:
1. Front knuckle assembly including upper arm (for convenience) and brake lines
2. Rear trailing arm assembly with brake lines and ebrake cables
3. Civic 15/16" MC from 1991 Civic EX or 1994-1995 Integra RS
4. 40/40 Prop valve not necessary, but can be installed from a 1990-1993 Integra or 1994-1995 Integra RS
Old Feb 13, 2006 | 12:52 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: Need some info on brake swap for my 92 civic (BlueIntegraBoy)
That list is correct. For any more details, go here.
https://honda-tech.com/zerothread?id=1513752
Old Feb 13, 2006 | 12:54 AM
thanks. for the front knuckle and rear trailing arms, are they the same for all 94+ integras. i dont want to install abs so if i buy integra brakes that are equiped with abs, are there any other mods necessary for install.
Old Feb 13, 2006 | 01:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 &raquo;</TD></TR><TR><TD CLASS="quote">thanks. for the front knuckle and rear trailing arms, are they the same for all 94+ integras. i dont want to install abs so if i buy integra brakes that are equiped with abs, are there any other mods necessary for install. </TD></TR></TABLE>
All the same. Doesn't matter if the car is ABS or not, it will bolt up to your car without any modifications.
Old Feb 13, 2006 | 01:14 AM
thanks for the info.
Old Feb 13, 2006 | 11:11 AM
i might buy the MC and the Prop Valve from someone online and was wondering if anyone knows if there is any part number on these so i would know its for a 94-95 integra rs.
Old Feb 13, 2006 | 12:25 PM
BIGGINS LS-VTEC's Avatar
you dont use the integra there is a bolt up post on here about it you use the acura legend
Old Feb 13, 2006 | 04:38 PM
Default Re: Need some info on brake swap for my 92 civic (BIGGINS LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGINS LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">you dont use the integra there is a bolt up post on here about it you use the acura legend
Huh?
Old Feb 15, 2006 | 08:46 AM
do i also need the integra brake booster if i buy the mc? is it a direct bolt on.
Old Feb 15, 2006 | 09:06 AM
You only need the Integra BB if you are using an Integra MC.
Old Feb 25, 2006 | 05:03 PM
MENACEteg's Avatar
So the 91 Civic 4-door EX brake MC is 15/16 and will bolt up directly to the stock EG brake booster with no mods?
Old Feb 25, 2006 | 05:14 PM
Default Re: Need some info on brake swap for my 92 civic (MENACEteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MENACEteg &raquo;</TD></TR><TR><TD CLASS="quote">So the 91 Civic 4-door EX brake MC is 15/16 and will bolt up directly to the stock EG brake booster with no mods?</TD></TR></TABLE>
Yes.
susy76
30
Sep 10, 2012 11:44 PM
IChazI
Mar 22, 2008 12:41 AM
mymeatb18"
Suspension & Brakes
Apr 12, 2007 11:08 AM
C uR eX
May 19, 2006 09:34 PM
