help guys 92 teg code 15 no start
Old Feb 12, 2006 | 09:03 PM
Timmay's Avatar
Default help guys 92 teg code 15 no start
ignition output code 15
no blown fuses
getting power to the black/yellow wire
tried 2 ecu's tried 2 distributors
Old Feb 13, 2006 | 01:19 PM
norcalintegra's Avatar
Default Re: help guys 92 teg code 15 no start (Timmay)
I have the exact same problem with my 1994 integra. Turns over but will not start. Changed spark plug wires, spark plugs, distributor cap, rotor and ignition control module. Car reads out code 15 "ignition output signal". Any one out there have any ideas for us?
Old Feb 13, 2006 | 01:21 PM
SlammedDC2teg's Avatar
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
65 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Old Feb 13, 2006 | 02:46 PM
Timmay's Avatar
Default Re: help guys 92 teg code 15 no start (SlammedDC2teg)
wow that helped LOL we already know what code it is
Old Feb 13, 2006 | 02:56 PM
LSracing94's Avatar
i had this code, it was my ignitor coil, you have the buy a full new distributor to get this part unless you want to spend 200+ dollars for it at honda/acura, but you would be better off getting a new distributor. I do notice that you said you tried 2 different distributors, are you sure that these distributors are in proper working condition, if so, then we can conclude that your problem is NOT your igntion output signal. Be sure that you are reading the code correctly from your ECU. Anyone feel free to correct me if i am wrong. -brian
Old Feb 13, 2006 | 02:59 PM
Timmay's Avatar
Default Re: help guys 92 teg code 15 no start (LSracing94)
ive tried 2 distributors 1 is almost brand new
tried a different coil and ignitor in the used dizzy
tried 2 different ecus
Old Feb 13, 2006 | 03:39 PM
LSracing94's Avatar
are you getting spark?
Old Feb 13, 2006 | 03:52 PM
Timmay's Avatar
no spark
Old Feb 13, 2006 | 04:27 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">i had this code, it was my ignitor coil, you have the buy a full new distributor to get this part unless you want to spend 200+ dollars for it at honda/acura, but you would be better off getting a new distributor. I do notice that you said you tried 2 different distributors, are you sure that these distributors are in proper working condition, if so, then we can conclude that your problem is NOT your igntion output signal. Be sure that you are reading the code correctly from your ECU. Anyone feel free to correct me if i am wrong. -brian</TD></TR></TABLE>
you dont have to buy a new dist. to repalce the igniter.
replace the distributer. i had the same code, replaced with a known working one and had no issues whatsoever.
also, the code means something is wrong in the distributor
Old Feb 13, 2006 | 04:33 PM
Timmay's Avatar
Default Re: (4sd4dr)
im afraid of trying another one and hurting it if there is something else wrong
Old Feb 14, 2006 | 06:46 AM
LSracing94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">
also, the code means something is wrong in the distributor</TD></TR></TABLE>
youre right you dont have to replace the distributor to replace the ignitor, but try to find somewhere that sells the ignitor separately for under 200 dollars...thats why i said he is better off just getting a new distributor..next time read my post a little better before you tell me i am wrong.
Old Feb 14, 2006 | 01:59 PM
bks84's Avatar
Loved
Default Re: (LSracing94)
youre right you dont have to replace the distributor to replace the ignitor, but try to find somewhere that sells the ignitor separately for under 200 dollars...thats why i said he is better off just getting a new distributor..next time read my post a little better before you tell me i am wrong.</TD></TR></TABLE>
the ignitor is like $50 bucks dude. actually, its less than that. I've replaced it before.
Old Feb 14, 2006 | 02:13 PM
Timmay's Avatar
ended up using anohter distributor, i had 2 bad ones
it wasnt the coil or ignitor
Old Feb 14, 2006 | 06:22 PM
LSracing94's Avatar
Default Re: (Timmay)
hahaah ignitor 50 bucks hahahahahahahahaha
Old Feb 14, 2006 | 06:25 PM
bks84's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">hahaah ignitor 50 bucks hahahahahahahahaha</TD></TR></TABLE>
are you kidding me...
i remember paying $50 from Oreilly's for mine. so dont be a fuckstaind like half the other useless ***** on here
Old Feb 14, 2006 | 06:37 PM
Vtak DOHCTA's Avatar
advanced sells 'em for $60
Old Feb 14, 2006 | 06:59 PM
bks84's Avatar
Loved
Default Re: (DOHCta VtAkmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCta VtAkmn &raquo;</TD></TR><TR><TD CLASS="quote">advanced sells 'em for $60</TD></TR></TABLE>
Thank you very much.
Old Feb 14, 2006 | 08:19 PM
GTWITIT's Avatar
I had this prob with my 91, no spark and code 15. Tried 2 dizzys and then when i gabe the borrowed ones back they didnt work either. Black and yellow wire had had corrosion on it and brook off from the harness,was grounding out on the frame shorting the coils. caused me 2 buy 2 dizzys for other people and a coil 4 me ouch
Old Feb 15, 2006 | 05:10 AM
LSracing94's Avatar
Thank you very much.</TD></TR></TABLE>
thank you very much, you are both wrong lol...stop trying to prove me wrong already because i know exactly what i am talking about and now i am going to just make you look stupid. youre just trying to say youre right but youre not cuz no one on this forum can admit they are wrong sometimes. the ignition coil and the ignitor are two completely different parts. you people are referring to the ignition coil. for example, http://shop.acurapartstore.com/?make=AC&year=1994 is for the IGNITER at 200+ dollars, gee what do ya know !?!!?and this http://shop.acurapartstore.com/?make=AC&year=1994 is for the IGNITION COIL, thank you..now realize you are wrong and suck it up.
Old Feb 15, 2006 | 09:14 AM
thank you very much, you are both wrong lol...stop trying to prove me wrong already because i know exactly what i am talking about and now i am going to just make you look stupid. youre just trying to say youre right but youre not cuz no one on this forum can admit they are wrong sometimes. the ignition coil and the ignitor are two completely different parts. you people are referring to the ignition coil. for example, http://shop.acurapartstore.com/?make=AC&year=1994 is for the IGNITER at 200+ dollars, gee what do ya know !?!!?and this http://shop.acurapartstore.com/?make=AC&year=1994 is for the IGNITION COIL, thank you..now realize you are wrong and suck it up. </TD></TR></TABLE>
i wonder.....if you fed this guy viagra he might grow taller......what a d*** head wannabe-know-it-all's got his head up somethin
Old Feb 15, 2006 | 09:26 AM
LSracing94's Avatar
i wonder.....if you fed this guy viagra he might grow taller......what a d*** head wannabe-know-it-all's got his head up somethin</TD></TR></TABLE>
okay maybe i was being a d*ckhead about it but the point of this forum is to get the correct information out there, and people are trying to tell me that i am wrong, but im not, you would get mad too.
Old Feb 15, 2006 | 09:35 AM
well both parts almost have the same name, so it would be easy to confuse.....just a miscommunication i think...however if Timmay needs an IGNITOR, i happen to have a few laying around I'd sell for cheap....also try testing the coil and the ignitor while the battery is connected to see if the current is right, that would be easier more accurate information than changing out and trying other dizzys, and you wouldn't be hurting anyone elses dizzy
Old Feb 15, 2006 | 12:58 PM
bks84's Avatar
Loved
nice response. LSracing94, i could careless. I replaced my ignitor and coil at the same time, the total was $124 for both. no, they arent OEM parts from Honda, they were from Oreilly Auto Parts.
Get off your highhorse, some people get better deals than you do.
14baldo66
May 3, 2021 05:50 PM
98tegLSvtec
Jul 31, 2011 01:33 PM
nismok720
Mar 27, 2011 07:15 AM
420aNT
Jun 5, 2003 09:23 PM
LSVTEC408
Dec 10, 2002 04:22 PM
