Code 8,16,41 help!!!
Old Mar 26, 2011 | 03:58 PM
nismok720's Avatar
Default Code 8,16,41 help!!!
I have run the cel and i have code 8 16 and 41 i have changed the injectors and the dist and still have the same problem i have also reset the ecu. Im out of ideas ? Car runs good just wont rev over 3500 please help Thanks
Old Mar 26, 2011 | 03:59 PM
nismok720's Avatar
Default Re: Code 8,16,41 help!!!
Its also a 1994 honda accord Lx Automatic
Old Mar 26, 2011 | 04:50 PM
curtie94's Avatar
Well here are the codes:
Engine Control Module
HO2S Or O2S
HO2S Or O2S{2}
VSS{1}
MAP Sensor
CKP Sensor{2}
Vacuum Switch{1}
MAP Sensor
ECT Sensor
TP Sensor{2}
M/T Clutch Switch Signal{1}
A/T Shift Position Signal{1}
TDC{2}
Ignition Coil Signal{1}
No. 1 Cylinder Position Sensor
10
IAT Sensor
12
EGR System
13
BARO Sensor
14
IAC Valve{2}
EACV{1}
15
Ignition Output Signal
16
Fuel Injector System
17
VSS
19
Lock-Up Solenoid Valve
20
Electric Load Detector
21
VTEC Solenoid Valve
22
VTEC Pressure Switch
23
KS
30
A/T FI Signal A
31
A/T FI Signal B
41
HO2S Heater
43
Fuel Supply System
48
HO2S{3}
{1}PGM-CARB.
{2}PGM-FI four cylinder engines.
{3}D5Z1 engine except California.
Old Mar 26, 2011 | 04:54 PM
lazlong's Avatar
I would start with the TDC sensor.
Old Mar 26, 2011 | 05:35 PM
nismok720's Avatar
The Tdc is in the dizzy right ? I put 3 distributor in it and also changed the fuel injectors and cleared ecu still the same codes ? I just don't see all theses distributors being bad ? I also noticed when i turn the key on the fuel pump never shuts off ?
Old Mar 26, 2011 | 06:09 PM
lazlong's Avatar
Yes.
Look at the primary O2 sensor. Are the wires all connected and tight? If yes, test according to the service manual. Sorry, don't know the specs.
With the other problems your having I'm suspecting you might have an ECU problem or bad wires. Try checking over the wire harness, especially where it goes thru the firewall.
Old Mar 26, 2011 | 06:56 PM
nismok720's Avatar
i checked the dist its within range according to the service manual so the only thing left is ecu or wiring harness. Ive notice there are some burnt wires behind the dash. Im sure thats my problem. How big of a job is changing the harness ? Thanks
Old Mar 27, 2011 | 01:16 AM
lazlong's Avatar
It's big. If you've never done it then it's a HUGE job. Set aside a whole weekend- at least. I would highly recommend a couple of friends to help.
If it's only one spot, cut and fix the wires one-by-one. I would use butt-connectors as they're easy and are less prone to breakage that solder. If it's mandatory to use butt connectors in aircraft then it's good enough for my car.
Old Mar 27, 2011 | 07:15 AM
nismok720's Avatar
Aight well ill let you know how it goes. Thanks
Laz's EP
22
Feb 22, 2010 12:09 AM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
Racersky
Apr 29, 2006 02:31 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
