ls v-tec
i want to do a ls v-tec to my 94 ls integra and was i wondering if any one could help me out with everything that i have to do to get this done right and everything that needs to be swapped out
This is a parts list to put together a basic B20/LSVTEC long block.
• VTEC Cylinder Head Assembly (B16, GSR, ITR)
• B20/LS Block
• B20/LS Head Gasket (depending on which block you go with)
• Stepped dowel pins
• Cylinder Head Drain Plug (1/8” NPT plug and tap)
• VTEC Oil Supply Line
• GSR/ITR Head Studs/Bolts
• LS/B20 Water Pump and Timing Belt or GSR/ITR/B16 Water pump and Timing belt
• B20/LS Block
MAYHEM
Sep 28, 2003 09:16 PM
