Wheel spacers 4x100 to 114.3 swap.
Old Feb 12, 2006 | 09:32 AM
BucDB's Avatar
Default Wheel spacers 4x100 to 114.3 swap.
Has anybody ever used these wheel spacers before to go from 4x100 to 114.3? Any mods needed?
Old Feb 12, 2006 | 09:51 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Wheel spacers 4x100 to 114.3 swap. (BucDB8)
ive seen a post like this before. They just bolt right on, but then your wheel may look a little funny because it will stick out a little bit more. Plus, if you are gonna do that, make sure its a good company and made strong. Whenever I look at those I think they would break so easily.
Old Feb 12, 2006 | 10:27 AM
Solscud007's Avatar
yeah jsut imagine that your sotck lugs need to fit flush agaisnt the hub of the spacer. otherwise the lug nuts will hit the back of your wheel
Old Feb 13, 2006 | 09:58 AM
BucDB's Avatar
Default Re: (Solscud007)
coo... thanks.
Old Mar 14, 2006 | 08:46 PM
xyzalvarez's Avatar
Default Re: (BucDB8)
i got the same kit...but just 4x100 spacers..
the oem studs go into the spacers holes...the provided bolts dont sit totally but enough to tight the spacer to the wheel hub...
Old Mar 14, 2006 | 08:54 PM
Sic_DA_Nine's Avatar
where did you find those?
Old Mar 14, 2006 | 09:04 PM
xyzalvarez's Avatar
they came with a set of wheels , but now im selling them...
Old Mar 14, 2006 | 09:49 PM
Sleepy_Red_hatch's Avatar
Default Re: (xyzalvarez)
i don't get it? do you pound out your old studs and bolt this through the holes left over?
Old Mar 14, 2006 | 11:19 PM
ImXposed's Avatar
Needs $$ for a Hooker
Default Re: (Sleepy_Red_hatch)
i don't understand how that would work.
Old Mar 15, 2006 | 07:23 AM
93_teg_CT's Avatar
Default Re: (ImXposed)
It looks pretty simple to me. Although I could be wrong, I have no experience with those.
Your studs, spaced 4x100 go into the holes on the wheel spacer. You bolt it to your hub with the nuts provided, the studs comming off the spacer are spaced to what you want to fit your new wheel, ie;4x114
Old Mar 15, 2006 | 07:29 AM
Default Re: (93_teg_CT)
its gunna push the wheel way out if you use those nuts to bolt it onto your reg hub
Old Mar 15, 2006 | 08:12 AM
iH8RICERZ's Avatar
Default Re: (97dC4)
how thick are those spacers?
Old Mar 15, 2006 | 08:18 AM
Guess whos bizzack
Default Re: (iH8RICERZ)
you can get them in different sizes, start at 15mm and go to 50 i think, but like I said a month ago when this post was up, you gotta think about strength of these things, i mean I would be scared using one of those
Old Mar 15, 2006 | 08:50 AM
BACKintheDA's Avatar
Default Re: (BOLO-FTW!!)
i believe wheelchoice also sells them.
xyzalvarez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">It looks pretty simple to me. Although I could be wrong, I have no experience with those.
Your studs, spaced 4x100 go into the holes on the wheel spacer. You bolt it to your hub with the nuts provided, the studs comming off the spacer are spaced to what you want to fit your new wheel, ie;4x114</TD></TR></TABLE>
yeah ! thats the way it works...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">how thick are those spacers?</TD></TR></TABLE>
you can have from 12mm to 50mm or maybe more...
Midori Green
15
Jan 1, 2008 10:39 PM
court
Jan 17, 2006 09:50 PM
Blazin Civic
Jun 27, 2005 01:17 PM
ripthesystem
12
Sep 16, 2003 06:31 AM
civbeater90
Aug 5, 2002 11:26 PM
