when are extended wheel studs required?
Old Aug 5, 2002 | 05:16 AM
civbeater90's Avatar
Default when are extended wheel studs required?
when is it necessary to use the extended wheel studs?is it because of rim size?or hp?
Old Aug 5, 2002 | 05:30 AM
PM-Performance's Avatar
Default Re: when are extended wheel studs required? (civbeater90)
i think its becase of the offset of the wheel not allowing the reg lugnuts to get threaded enough
like bogarts, you usually wont get enough threads on the lugnuts to be safe becuase the offsets are diff. .
Old Aug 5, 2002 | 10:58 AM
martini's Avatar
Default Re: when are extended wheel studs required? (itr206)
the offset is the distance between the hub mounted surface, and the centerline of the wheel, so it has nothing to do with longer studs..but I know what you are trying to say.
The thickness of the mounting point of the wheel can sometimes change when putting on slicks or other wheels, and as per NHRA rules,
"All wheel studs must project into the hex portion of the lug nut by a distance equal to one diameter of the stud" (Section 5:2)
Old Aug 5, 2002 | 11:01 AM
martini's Avatar
[Modified by martini, 12:03 PM 8/5/2002]
Old Aug 5, 2002 | 04:02 PM
Default Re: when are extended wheel studs required? (martini)
hey guys thanks for the response.i have some long ones on my hubs.but i hae yet to mount them on the car.i just hink they are gonna look funny daily driven.
Old Aug 5, 2002 | 05:05 PM
ExospeedAMcrx's Avatar
it wont look funny. it'll look badass! hehe
Old Aug 5, 2002 | 08:12 PM
sparkz's Avatar
Default Re: when are extended wheel studs required? (exospeedAMcrx)
which make me wonder, will lenso pass nhra tech?
Old Aug 5, 2002 | 09:41 PM
Ludehrt's Avatar
Default Re: when are extended wheel studs required? (sparkz)
Staying on the subject..kinda
Im going to be running 15x22x8 MTs slicks on some light weight Einki Rp01s in a couple of days. Do these require longer wheel studs to pass tech?. To those familiar with the NHRA rules, are longer wheel studs required when any type of racing slick is used?
Another Question, Are the ARP wheel studs application that you guys mentioned for the Civic/Ingera also fit on a 4Gen Accord or a Prelude?
Thanks in advance
Those longer wheel studs look pretty mean on the street. Kinda gives ya the .."You better not @#$% with me" look
[Modified by Ludehrt, 6:43 AM 8/6/2002]
Old Aug 5, 2002 | 11:26 PM
sparkz's Avatar
nevermind, just read and reread the nhra sport compact rulebook. they are legal as long as you dont put a spacer on them (no need to) and pretty much any wheel that require spacers will also require extended lugs.
743power
182
May 19, 2017 07:30 AM
Iloveyourhonda92
34
Jun 9, 2010 11:31 PM
Midori Green
15
Jan 1, 2008 10:39 PM
Blazin Civic
Jun 27, 2005 01:17 PM
