!!!! idle prob > i did the coolant bypass!!!!!
Old Feb 12, 2006 | 07:39 AM
nekoabandoned's Avatar
Default !!!! idle prob > i did the coolant bypass!!!!!
ok i have the weird idle thing where when you stop at a light my idle goes up and down over and over. after trying everything this site has to offer i decided to do a coolant bypass(if u dont already know what it is look here: https://honda-tech.com/zerothread?id=1423187 ) ur basicly bypassing the coolant lines to the FITV,IACV,and the TPS. any help on what could cause the idle even after the bypass other than a vacuum leak would be great.
ps i did check for a vacuum leak
Old Feb 12, 2006 | 12:24 PM
Default Re: !!!! idle prob > i did the coolant bypass!!!!! (nekoabandoned)
bump for some help
Old Feb 12, 2006 | 12:26 PM
JDM-97CX's Avatar
Try thinking?
What affects idle? Start there.
Old Feb 12, 2006 | 12:32 PM
Default Re: !!!! idle prob > i did the coolant bypass!!!!! (JDM-97CX)
thanks for the advice ,but maybe you can try and think of a way to help instead.
Old Feb 12, 2006 | 12:34 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advice ,but maybe you can try and think of a way to help instead.
I just did, what do you learn if I just tell you what it is? Nothing. It would also be wise in the future to not treat one of the only REAL techs on this site with any disrespect.
Now what keeps idle constant?
Old Feb 12, 2006 | 12:36 PM
thursday's Avatar
i built a block off plate and removed the unit when i bypassed.
Old Feb 12, 2006 | 12:37 PM
Default Re: (thursday)
tps,iacv yadda yadda
Old Feb 12, 2006 | 12:40 PM
JDM-97CX's Avatar
Default Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">tps,iacv yadda yadda</TD></TR></TABLE>
TPS wont cause this.
Old Feb 12, 2006 | 12:41 PM
Default Re: (JDM-97CX)
ok can i get a hint...
Old Feb 12, 2006 | 12:43 PM
JDM-97CX's Avatar
I'd take a close look at the IAC. It is the only thing that can cause an idle problem like this and not cause a problem anywhere else in the power band.
Old Feb 12, 2006 | 12:44 PM
thursday's Avatar
you may need to build a block off plate, that's what i am getting at, although your unit has no water running through it, it could still be adjusting the idle. Or it can have its adjustment stuck at a certain place.
It may not be your IACV at all, its kind of a hands on thing. You may just have to mess around and try different things, in fact, you will have to. Let us know, good luck
Old Feb 12, 2006 | 12:45 PM
well my mids kind of slugish( 3.5-5k) latly. and i did do a plate
Old Feb 12, 2006 | 12:48 PM
JDM-97CX's Avatar
I could see a whole lot of things causing a slugginsh midrange. But nothing that would cause this problem as well.
Old Feb 12, 2006 | 12:52 PM
guess ill go get dirty again, ill post soemthing if i can find the problem
WhiteTrashedDA9
May 2, 2013 08:40 AM
deeweezy187
Dec 3, 2005 08:50 PM
Ian in Oz
Jun 4, 2003 10:21 AM
