will this filter hurt performance on my 35R
I recently bought a GT35R .63 a/r. Now i dont have a lot of room and basically i can run this size filter
not my car
i found a few 4" k&n filters heres some specs
Shape: Conical
Length (in): 5
Inlet Flange Inside Diameter (in): 4.00
Top Diameter (in): 4.50
Bottom Diameter (in): 5.375
Length (in): 5
Top Diameter (in): 4.375
Shape: Conical
Length (in): 3 1/2
Bottom Diameter (in): 4.375
Shape: Round straight
Length (in): 6.000
Top Diameter (in): 7.00
Bottom Diameter (in): 7.000
you guys think it will affect performance a lot. Should i run without a filter at the track. I might try on the dyno and see if it makes a diff... I plan on running around 20-24psi
not my car
Shape: Conical
Length (in): 5
Length (in): 5
Shape: Conical
Length (in): 3 1/2
Length (in): 6.000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 »</TD></TR><TR><TD CLASS="quote">no and plz use it </TD></TR></TABLE>
eric
eric
expensive turbo vs cheap k&n filter.......id think id rather save the turbo.....also, i would never run without a filter, u never know what could get sucked up in there, even a tiny rock would do some damage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster »</TD></TR><TR><TD CLASS="quote">expensive turbo vs cheap k&n filter.......id think id rather save the turbo.....also, i would never run without a filter, u never know what could get sucked up in there, even a tiny rock would do some damage</TD></TR></TABLE>
where did you get cheap k&n from..... Of corse in not going to run without a filter..
Length (in): 6.000
I think I have this one on my turbo. It might be 5", not sure. But I didn't notice a difference when I put it on. I was running some mesh a few days before I could get to a jegs and get a filter.
Length (in): 6.000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stiffmeister »</TD></TR><TR><TD CLASS="quote">no i actually need to buy the same filter for mine...</TD></TR></TABLE>
yea ya do haha
yea ya do haha
Had the same filter on a car I helped with. Went to the dyno with Mase. Pulled 6whp peak without the filter. Is it worth it? Hell yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">Had the same filter on a car I helped with. Went to the dyno with Mase. Pulled 6whp peak without the filter. Is it worth it? Hell yes.</TD></TR></TABLE>
Nice i might be pulling the filter for track days only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CashmoneyUKR »</TD></TR><TR><TD CLASS="quote">Nice i might be pulling the filter for track days only</TD></TR></TABLE> Your call man, Is like 30 bucks and 6hp worth buying a new turbo if something gets sucked in there?
FBP Si 2000
Feb 27, 2003 12:44 PM
