crx si b16 distributor help, plugs dont fit, 7wires-5wires.please
Old Feb 11, 2006 | 06:13 PM
SPITVENOM67's Avatar
Default crx si b16 distributor help, plugs dont fit, 7wires-5wires.please
ok so i have the stock 89 si harness and a b16a motor everything else will fit other than the distributor plugs. The ones on the b16 dizzy, one fits and the other doesnt (it has 7 wires) the harness plug has 5 wires, where do the other wires go wat can I do about this I need this info pleasee...
Default Re: crx si b16 distributor help, plugs dont fit, 7wires-5wires.please (SPITVENOM67)
help meeeee
Old Feb 11, 2006 | 07:14 PM
xaine's Avatar
your info sir read and you will find
http://b16a.honda-perf.org/theswap.html
Old Feb 12, 2006 | 06:43 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPITVENOM67 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i have the stock 89 si harness and a b16a motor everything else will fit other than the distributor plugs. The ones on the b16 dizzy, one fits and the other doesnt (it has 7 wires) the harness plug has 5 wires, where do the other wires go wat can I do about this I need this info pleasee... </TD></TR></TABLE>
Si harness has round 7 wire connector at the distributor - DX harness has square 5 wire connector - are you sure you have Si harness?
Old Feb 12, 2006 | 01:16 PM
Default Re: crx si b16 distributor help, plugs dont fit, 7wires-5wires.please (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
Si harness has round 7 wire connector at the distributor - DX harness has square 5 wire connector - are you sure you have Si harness?</TD></TR></TABLE>
im absolutelly sure its a si harness I took this out my 89 crx si...is there anything I can doo???
Old Feb 12, 2006 | 04:31 PM
cmon guys im in a pickle here lol...wats the solution??
Old Feb 12, 2006 | 04:43 PM
charliev's Avatar
is your car actually an si cuz u cant just put the si harness onto the dx/std chasis harness w/o modification
Old Feb 12, 2006 | 04:55 PM
Default Re: (charliev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliev &raquo;</TD></TR><TR><TD CLASS="quote">is your car actually an si cuz u cant just put the si harness onto the dx/std chasis harness w/o modification</TD></TR></TABLE>
yes dude its actually and SI I mean OEM sunroof and everything...
Old Feb 13, 2006 | 12:48 AM
up up up
Old Feb 13, 2006 | 12:54 AM
Rywire's Avatar
If you have 5 pins in your main dizzy plug, and the plug is square, you have a dx!
Old Feb 13, 2006 | 08:27 AM
Default Re: crx si b16 distributor help, plugs dont fit, 7wires-5wires.please (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">If you have 5 pins in your main dizzy plug, and the plug is square, you have a dx! </TD></TR></TABLE>
damn everyone has beend saying this well the car is an SI and had a zc dohc with mpfi my quiestion is this if I get a si harness will everything be cool?
Old Feb 13, 2006 | 08:38 AM
jlicrx's Avatar
the DOHC ZC distributor uses a square 5 wire connector like on the DX - when the ZC was swapped in, they had to swap the connector - the other 2 wires on the ZC went to the CYL sensor on the end of the exhaust camshaft - one blue with yellow stripe and one blue with green stripe - you need a Si or HF round 7 wire connector to swap onto your harness - put the 2 CYL sensor wires back into that connector to match the location on the connector on the distributor
Old Feb 13, 2006 | 10:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">the DOHC ZC distributor uses a square 5 wire connector like on the DX - when the ZC was swapped in, they had to swap the connector - the other 2 wires on the ZC went to the CYL sensor on the end of the exhaust camshaft - one blue with yellow stripe and one blue with green stripe - you need a Si or HF round 7 wire connector to swap onto your harness - put the 2 CYL sensor wires back into that connector to match the location on the connector on the distributor </TD></TR></TABLE>
there you go, this guy knows his s^%&T thas teh anwers I was looking for buddy, your badass dawg.. thanks bro
Old Feb 13, 2006 | 11:40 PM
bigcalidave's Avatar
Yeah, beat me to that one jlicrx...
Old Feb 14, 2006 | 12:33 AM
Rywire's Avatar
Well, if you told us the full story the first time it would have been obvious...
Old Feb 14, 2006 | 01:44 AM
HondaPartsHero's Avatar
Technical Hero
If you need a 7 wire Si engine harness plug to plug into the distributor to replace the 5 wire plug let me know I have a couple laying around here, $5 dollars shipping included to where ever you are
Old Feb 14, 2006 | 12:57 PM
thanks everyone problem solved....
ninty1civic
19
Nov 9, 2009 07:40 PM
JohnCRX
Aug 20, 2004 08:21 AM
b18cvtec
Dec 2, 2003 05:41 PM
freeeked
Aug 30, 2003 02:27 AM
