tires question: is 225/50/15 too wide on stock gsr rims?
Old Mar 26, 2002 | 10:17 AM
chi@1001's Avatar
New User
Default tires question: is 225/50/15 too wide on stock gsr rims?
i am about to purchase 4 205/50WR15 Bridgestone Potenza S-03 from tirerack.com
but i just found that the 225/50/15 just cost 10 bucks more each.
so i am wondering if is ok to have such wide tires on??
i have GSR stock rims, and i have sportline springs on.
would the 225 tires gonna cost any problem??
or i should just go with 205/50??
thanks a lot
Old Mar 26, 2002 | 10:27 AM
gsrboy01's Avatar
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (chi@1001)
correct me if im wrong, but i think that 205 is the widest you can go on the stock 15's.
Old Mar 26, 2002 | 10:35 AM
chi@1001's Avatar
New User
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (gsrboy01)
yeah, that's what i'd like to make sure ....
Old Mar 26, 2002 | 10:41 AM
RC211V's Avatar
No way!!!! it is way too wide. 205 on 15's the tires buldge out a littlebit so a 225 would be way too big. just go with sticky 205's and you should be ok with traction. speaking of traction, i think they make a t1-s for a 15 you should look into a t1-s. they grip like Whoa!!!
Old Mar 26, 2002 | 10:42 AM
Reid's Avatar
Global Moderator
I mount 225/50/15 Kumho V700s and 225/45/15 Hoosier AS303s on stock ITR wheels (15x6). I assure you the Hoosiers are one of, if not the widest, 225 tires out there.
In conclusion your tires will fit.
EDIT: But for daily driving I'd stick to 205/50/15.
[Modified by Reid, 9:44 AM 3/26/2002]
Old Mar 26, 2002 | 11:05 AM
project_DC2's Avatar
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (Reid)
[/QUOTE]
[Modified by Reid, 9:44 AM 3/26/2002][/QUOTE]
Im thinking of 215 in front and 205 in back! Oops..thats for 16'
stick w/ 205 NOT 225 for daily driving
Old Mar 26, 2002 | 11:19 AM
bps2799's Avatar
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (project_DC2)
Take a look at tirerack's "spec" section for the tire you're looking at, which will have the rim width range for each size tire (stock = 6" wide).
Personally, 215/50-15 is what I'd go for since the diameter would be almost identical to the stock tires.
Old Mar 27, 2002 | 12:04 AM
chi@1001's Avatar
New User
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (bps2799)
thx for your help..
another question:
which is better?
Dunlop SP 9000 or Bridgestone Potenza S03?
both with 205/50/15..
thx
Sp 9000 is cheaper though
Old Mar 27, 2002 | 12:41 AM
slowerthanu's Avatar
New User
from everything i have read, the SO-3's own. I just got some and I am mounting them tomorrow.
Old Mar 27, 2002 | 05:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (slowerthanu)
Not only would 225/50 be too wide, it would be too large in diameter. Your car would sit higher, your acceleration would suffer, your cruising speed would be faster than what is indicated on the speedometer. Not to mention you would no doubt rub all over the place.
Old Mar 27, 2002 | 06:11 AM
berkel's Avatar
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (PatrickGSR94)
Hey,
I would go for the Bridgestones, I had the SP 9000 and they were great in the rain, but dry traction wasn't that great. Prob not as good as SP 8000 which are much cheaper (I have SP 8000 on my A4).
As for width, that's prob too wide for street tires , but remember the width of the wheel is very important, and stock GSR wheels are fairly narrow. You have to work within the overall diameter, width for given wheel, and then worry about rubbing too, heh.
FB
Old Mar 27, 2002 | 07:29 AM
Rainmaker's Avatar
Wait, that's too wide. 205/50/15 is the closest match to 195/55/15. Also, back to the 225s, 225s will fit on a stock height Integra, but will require spacers, and will need to be a tire with a very strong sidewall (such as the V700s mentioned above). Of course the V700s are DOT slicks. You should not go higher than 205/50 on the stock rims for the street. If you are lowered, they probably will rub on the fenders.
Rainmaker.
Old Mar 27, 2002 | 08:33 AM
bps2799's Avatar
Default Re: tires question: is 225/50/15 too wide on stock gsr rims? (Rainmaker)
Rainmaker.
Not so. Read the "spec" section at the TireRack. Many 215/50-15, if not all, will fit on 6" rims. The diameter is MUCH closer to stock than 205/50s, which you can also find at TireRack.
Main problem would be if the extra width will rub anywhere inside the fenderwell.
Old Mar 27, 2002 | 10:39 AM
Community Builder
However if you try putting 215's on 6" wheels, since the rim beads are being pushed in so far, the center of the tread may try to bulge out, causing problems with the center of the tread wearing down quicker. Something else to think about.
Old Mar 27, 2002 | 10:42 AM
chi@1001's Avatar
New User
thanks guys...
i will go for 205/50 potenza S03
Kapetan
14
Jan 11, 2006 07:36 AM
M-Type
Apr 1, 2003 10:32 AM
Trellis
Feb 4, 2003 04:19 PM
gsrpilot8000
Sep 16, 2002 02:09 PM
Lookincrazy
Apr 13, 2002 07:13 PM
