Going turbo on my d16z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Singlefury »</TD></TR><TR><TD CLASS="quote">i did some more research. found out that the d16y8 intake manifold wont fit on the d16z6 block. that suck.</TD></TR></TABLE>
This is incorrect, a Y8 manifold will work on a z6 HEAD.
The y8 intake mani will work on the z6. It's sometimes referred to as the type r of the d-series intake mani's... Someone just did a write up on it recently. I'll see if I can find it. BTW the intake mani attaches to the head not block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Singlefury »</TD></TR><TR><TD CLASS="quote">d15b block are high compression right. is that good for going turbo. </TD></TR></TABLE>
na... just harder to tune.
i dont understand why you would wanna go the the trouble rebuilding a D series with oem internals... Or B series unless its NA.
Buy a d16z6 and boost that. As for boosting z6 vs d15b Who cares? they are all going to limited by the ringlads or rods anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcupo12 »</TD></TR><TR><TD CLASS="quote">high compression is bad for boost, hence the b18c5 is bad for boost, unless your going to run 5psi on a gooooooood tune.</TD></TR></TABLE>
You have knowledge of the garbage spewing from your mouth by any chance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could »</TD></TR><TR><TD CLASS="quote">the d15b JDM sohc VTEC is said to be hondas finest sohc engine. boost that. the head is supposed to carry a more aggressive cam than all others also. that's what i will be doing.</TD></TR></TABLE>
I wouldn't waste my time with that engine... Having driven both the D15B and the D16Z6, I can tell you the 15B is a dog.
I'm sorry? Are you high? Maybe making LESS power is your goal.
94c1v1cex
Mar 30, 2007 04:52 PM
Do some research in the forced induction forums.
