5G Preludes with CF Hoods and no hood pins..... Question
Old Feb 10, 2006 | 10:19 AM
Proskater201's Avatar
Default 5G Preludes with CF Hoods and no hood pins..... Question
I have a carbon fiber hood and at about 80mph it feels like its gonna come off but i dont want hood pins. How can i make it stop flapping around without hood pins and drive at those speeds safely? Any suggestions would help greatly. Thanks
Old Feb 10, 2006 | 10:21 AM
VTecLude1994's Avatar
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (Proskater201)
You can't.
Old Feb 10, 2006 | 10:29 AM
Hawkze_2.3's Avatar
Lots of duct tape.
Old Feb 10, 2006 | 10:35 AM
The_Sober's Avatar
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (Hawkze_2.3)
install a second latch to hold it down from the inside...
Old Feb 10, 2006 | 10:39 AM
94Vtecluder's Avatar
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (The_Sober)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober &raquo;</TD></TR><TR><TD CLASS="quote">install a second latch to hold it down from the inside...</TD></TR></TABLE>
Even that notion is inherently impossible. If he did, how would he lock the latch so it says shut after he's closed the hood? After you solved that problem how is he going to unlatch the hood from the inside when it's closed?....
Old Feb 10, 2006 | 10:40 AM
DucDucSTFU's Avatar
sheetmetal screws........or buy a good hood......
Old Feb 10, 2006 | 10:42 AM
The_Sober's Avatar
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">Even that notion is inherently impossible. If he did, how would he lock the latch so it says shut after he's closed the hood? After you solved that problem how is he going to unlatch the hood from the inside when it's closed?....</TD></TR></TABLE>
I had to do it on a car once. It involves cutting & welding an additional latch to the front subframe next to the existing one. Then you have to put another hook on the hood. Then you have to install a secondary hood release--in my case, I put it under the front bumper. To open the hood, I had to pull the secondary release cable while somebody else pulled the primary one from the inside.
It's a pain in the ******* ***, but it kept my hood down...
Old Feb 10, 2006 | 10:49 AM
Ya well that's what i meant. I would require a decent amount of work and fab, and installation of a second switch etc. Then getting it to line up yadda yadda yadda. What I meant is there is no conventional way to add another latch.
Old Feb 10, 2006 | 11:02 AM
Just use pins and get over it. If pins mean that I won't have my hood fly up at 70 then so be it I'm using them.
Old Feb 10, 2006 | 11:07 AM
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (VTecLude1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTecLude1994 &raquo;</TD></TR><TR><TD CLASS="quote">Just use pins and get over it. If pins mean that I won't have my hood fly up at 70 then so be it I'm using them.</TD></TR></TABLE>
Ya I dont' know why everyone hates on hoodpins so much damn. If you want there are also carbon fiber hood keylock thing floating around online so you won't see it as much.
Old Feb 10, 2006 | 11:12 AM
VSBB6's Avatar
Radiator shroud does take away some of the vibration in my case.
Old Feb 10, 2006 | 11:17 AM
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (VSBB6)
I'm running the Forbidden Motorsports Radiator Shroud on my 4th gen, but my ViS Invader CF Hood is coming in next week and I'm using pins. I don't give a expletive...I don't want my hood flying open at 70.
Old Feb 10, 2006 | 11:25 AM
98vtec's Avatar
moderator emeritus
hoodpins
Old Feb 10, 2006 | 11:28 AM
Lewdin' Incognito's Avatar
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (98vtec)
If you don't like the look of hood pins, get the anodized (black) ones so they blend in.
Old Feb 10, 2006 | 12:34 PM
Default Re: 5G Preludes with CF Hoods and no hood pins..... Question (Lewdin' Incognito)
hmm i guess its hood pins then huh?
alacard
23
Jan 4, 2007 01:39 PM
trustbuddy
Nov 18, 2005 03:27 PM
malubawla
106
Sep 23, 2005 09:39 AM
DynastyRacer22
May 26, 2005 11:20 PM
ForceXVII
Dec 1, 2003 10:49 AM
