Jun 3 Camshaft ?
Old Feb 9, 2006 | 07:43 PM
milton's Avatar
Default Jun 3 Camshaft ?
I'm planing on upgrading my cams to jun3's. would the stock valves be a problem? I've been running my sk2 stg2 for a while. JW if the juns will be a problem?
Pros and Cons?
Old Feb 9, 2006 | 07:53 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Jun 3 Camshaft ? (milton)
i'd go ahead and upgrade valvetrain if it's stock, you might get rev happy and float a valve..
my .02
Old Feb 9, 2006 | 07:54 PM
milton's Avatar
Default Re: Jun 3 Camshaft ? (ohsnapzafingcu)
i mean i do have portflow valvesprings.. but stock valves.. i heard that they have issues with stock valves.. and need to have bigger valves?
Old Feb 9, 2006 | 08:18 PM
Uncle Willie's Avatar
I think you should be fine with the stock valves...all i think you need is the aftermarket springs and retainers. But you could go on the safe side and get some flat faced valves for .2 more compression also!! What compression ratio are you running? Tuning device?? I am interested to see what ur build consist of. It will happen someday for me also...i hope.
Old Feb 9, 2006 | 08:37 PM
milton's Avatar
Default Re: Jun 3 Camshaft ? (RIP Indian Larry)
My previous set up is
b18b1 block with b16 pistons (new rings)
Dual portflow valve springs
New Rod Bearings
New Gaskets (Crankcase and Head Gasket)
New Timing Belt + Tensioner + Waterpump
96 GSR Head
Skunk2 Stage2 Camshafts
ARP Rod BOlts with ARP Headstuds
New Exedy Racing Cluth (Stiff Pressure Plate)
95 GSR Tranny
Adjustable Cam Gears
B&M FPR
lighthened flywheel
Old Feb 9, 2006 | 08:38 PM
milton's Avatar
i wasnt too suprised with the power.. thus i had a turbo'ed integra b4 this.. thats probably why.. though all-mota is the **** hands down..
Old Feb 9, 2006 | 09:12 PM
biassj's Avatar
Aren't the Skunk Stg 2 basically Jun 3 copies?
Old Feb 9, 2006 | 09:45 PM
milton's Avatar
Default Re: Jun 3 Camshaft ? (biassj)
im not sure... how are the jun 4's?
Old Feb 14, 2006 | 01:22 PM
get a video up of how your car runs.. or take it to the trackk. orr orr tell us how it runs!.. or go get it tuned nd dyno'd!
Old Feb 14, 2006 | 08:57 PM
milton's Avatar
i will post soon... thanks
Old Feb 16, 2006 | 12:46 AM
kirby_lys's Avatar
Default camshaft smogged
Hey guys...Does anyone know what kind of perfomance camshaft will pass smog with no problem...Im trying to put some camshaft into my 95 integra to boost some speed, and not worry about smogging...thanks
Old Feb 16, 2006 | 07:36 AM
redGSRguy's Avatar
Default Re: camshaft smogged (kirby_lys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kirby_lys &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys...Does anyone know what kind of perfomance camshaft will pass smog with no problem...Im trying to put some camshaft into my 95 integra to boost some speed, and not worry about smogging...thanks</TD></TR></TABLE>
Are you in CA? Usually with more aggressive cams you won't pass smog unless you have cash in hand.
Old Feb 16, 2006 | 07:48 AM
Danza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biassj &raquo;</TD></TR><TR><TD CLASS="quote">Aren't the Skunk Stg 2 basically Jun 3 copies? </TD></TR></TABLE>
believe the intake cam is the same, exh is a little different, but basically
Old Feb 16, 2006 | 10:22 AM
milton's Avatar
Default Re: camshaft smogged (redGSRguy)
no need.. my home dawg gots a shop
turboman2.2
Jul 4, 2010 10:08 AM
Lil Krayzee
10
May 12, 2009 06:23 PM
Laojoeturbo
14
Feb 6, 2009 06:26 PM
toooslow
Jul 10, 2003 03:35 PM
SiBirdie
Dec 25, 2002 03:17 AM
