Prothane Motor Mount Inserts
Old Feb 9, 2006 | 04:20 PM
DRAGWORKS's Avatar
Default Prothane Motor Mount Inserts
I am wondering which Prothane Motor Mount Inserts I need. I have a 95 civic hatch with a b16 in it. Do I buy them for a 92-95 civic or do I buy them for a 99-00 SI for the motor.
Thanks
Old Feb 9, 2006 | 04:29 PM
Wannabe JDM's Avatar
Default Re: Prothane Motor Mount Inserts (DRAGWORKS)
depends which mounts are you using?
Old Feb 9, 2006 | 04:34 PM
mxpx035's Avatar
Default Re: Prothane Motor Mount Inserts (slowej)
buy them for a 94-01 teg because those are the mounts you are using
Old Feb 9, 2006 | 05:16 PM
DRAGWORKS's Avatar
Default Re: Prothane Motor Mount Inserts (mxpx035)
i am using the motor mounts the came with the b16a (complete swap from hmotors)
Integra upper drivers side mount is different than a b16
Old Feb 13, 2006 | 10:40 AM
DRAGWORKS's Avatar
anyone know?
Old Feb 13, 2006 | 11:43 AM
CALIdelsolSIR's Avatar
get them for a 93-95 DOHC VTEC Del Sol. Problem Solved.
Old Feb 13, 2006 | 11:44 AM
EX-T's Avatar
Default Re: Prothane Motor Mount Inserts (CALIdelsolSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALIdelsolSIR &raquo;</TD></TR><TR><TD CLASS="quote">get them for a 93-95 DOHC VTEC Del Sol. Problem Solved.</TD></TR></TABLE>
I'll have to agree with this one also!
Old Feb 13, 2006 | 12:07 PM
monicle's Avatar
which motor mounts are you using? those are the ones you buy.
Old Feb 13, 2006 | 01:26 PM
Default Re: Prothane Motor Mount Inserts (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">which motor mounts are you using? those are the ones you buy.</TD></TR></TABLE>
did that sentence make sense ? not sure what you are asking. go with energy, good inserts for cheap.
Old Feb 13, 2006 | 01:34 PM
freakasis's Avatar
the 3 torque mounts were prolly 92-95 civic ones....if you wanna do the others too than go with 94-01 integra.
Old Feb 13, 2006 | 01:43 PM
hondafan62269's Avatar
94+ Integra inserts, even the torque mount inserts.
99-00 Si have different style tranny mount and driver side mounts, so the bushings won't work.
Old Feb 13, 2006 | 01:44 PM
Also the inserts are gonna rattle your teeth out. If the car is driven daily, you might want to look at just a torque damper. It depends on what your looking at doing.
Old Feb 13, 2006 | 02:25 PM
freakasis's Avatar
Default Re: (hondafan62269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafan62269 &raquo;</TD></TR><TR><TD CLASS="quote">94+ Integra inserts.</TD></TR></TABLE>
if you are using eg mounts the inserts for the 94-01 teg are gonna be a little differant but you can cut them to work.....best to just figure out which torque mounts you have and use the right ones. if you dont know than just buy the eg ones and check it out.
bl1tzk1213g
May 16, 2007 10:31 AM
ilovejdmhoes23
Jan 18, 2007 04:32 PM
ivicr
Oct 30, 2005 01:10 AM
bluedelsol
Jun 4, 2003 07:13 AM
