Valve adjustment question (gaskets)
It's about time to do another valve adjustment and I've one quick concern. Is it recommended to replace the cam cover gasket and plug washers even if I replaced them on the last one, say, 25K ago? Thanks! Matt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 »</TD></TR><TR><TD CLASS="quote">haha bad analogy, there might be metal or cockroaches in taco bell. How about Outback Steakhouse to go?</TD></TR></TABLE>
no dont you watch tv commercials??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">
Screw Taco Bell & Outback. Taco Bell is like taking a self-bloating pill and I'm convinced Outback's steak must be kangaroo meat.
The only good chains are Chili's and Carabba's.
(goes to kitchen to make MY tacos along with Pete's lager)
</TD></TR></TABLE>Screw Taco Bell & Outback. Taco Bell is like taking a self-bloating pill and I'm convinced Outback's steak must be kangaroo meat.
25k is a long time.
You will probably be fine...but whyt risk it for 10 bucks in parts. And only put Hondabond on the corners of the VC gasket. I like to use Urea grease on the tube seals if I reuse them..helps seal out oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">nah...little hondabond and yer good to go like taco bell</TD></TR></TABLE>
Grilled up in a soft tortia.
