H22 in civic coupe
Old Feb 9, 2006 | 06:34 AM
96TEGgSR07's Avatar
Default H22 in civic coupe
I'm looking for a civic coupe and i was planning on puttin an H22 swap in it.. What i was wondering is how much will this full swap cost?.. Including mounts and everything i need.. thanks in advance for the help
Old Feb 9, 2006 | 06:48 AM
eg6nes's Avatar
Default Re: H22 in civic coupe (96TEGgSR07)
h22 motors are varly cheep compaired to k series motors they are about 2500 i think on hmotorsonline.com the mounts iam not shure how much they are, but hassport makes the kit. this swap is insane my friend has a h22 swap in his 93 coupe it ran a 13.4 on slicks.
(its not a stock h22)
Old Feb 9, 2006 | 06:57 AM
IHateJDM's Avatar
Default Re: H22 in civic coupe (primed)
look in the hybrid forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primed &raquo;</TD></TR><TR><TD CLASS="quote">h22 motors are varly cheep compaired to k series motors </TD></TR></TABLE>
and they are varly expensive compared to a d15 .
Old Feb 9, 2006 | 07:15 AM
kaoss_11's Avatar
B A N N E D
motor tranny 2200
mount kit 600
axles 350
misc things 1000 give or take
Old Feb 9, 2006 | 07:29 AM
Vero's Avatar
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">motor tranny 2200
mount kit 600
axles 350
misc things 1000 give or take</TD></TR></TABLE>
make those axels/swap more expensive.
H22 full swap aprox $2600 (3600 for type S)
Mounts $500
Axels $500 +/-
Misc 800 +/-
better advice?
H22 Longblock $1200
H2B Kit $900
B series Trans $400 +/-
B series mounts $3-450 depending on chasis
B series axels $150 +/-
B series linkage $100 +/-
ECU/EMS $150+
Misc $6-800 +/-
cheaper, quicker, less work, no custom axel crap.
PS: Hybrid forum.
Old Feb 9, 2006 | 07:51 AM
99exd16y8's Avatar
Default Re: (Vero)
I think I paird around 3500 for everything i needed, hasport mounts, raxle axles, conversion harness, etc. It was well worht every penny and i had money left over to get a sick header and a tune.
Old Feb 9, 2006 | 07:57 AM
96TEGgSR07's Avatar
Default Re: (99exd16y8)
Have you ran it at a track yet? any times? and is it really worth it. Also i believe im gonna do the H2B thing in time, but not as soon as i get it. Limited budget
Old Feb 9, 2006 | 07:58 AM
96TEGgSR07's Avatar
thanks everyone who has put in info.
Old Feb 9, 2006 | 08:03 AM
Vero's Avatar
Default Re: (96TEGgSR07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96TEGgSR07 &raquo;</TD></TR><TR><TD CLASS="quote">Have you ran it at a track yet? any times? and is it really worth it. Also i believe im gonna do the H2B thing in time, but not as soon as i get it. Limited budget</TD></TR></TABLE>
why bother cutting your car up when you just gonna put it back later. you can run an H2b for about the same price and start off with a stronger trans.
IHateJDM's Avatar
if you do h2b, you want to do it when you swap. the h22 tranny forces you to cut a bracket on the frame rail that holds the tranny mount, and you have to cut a hole for the shift cables in the car too. You don't have to do this for the H2B, and if you're taking out the H22 tranny later for a b tranny, you'll have to weld a new bracket to the frame rail, and weld an piece of metal back in the car for the shifter hole. Either do it when you swap, or you won't do it at all.
BTW, my H22 swap = $4k with HCP mounts, DSS axles, LSD tranny, clutch and flywheel.
Old Feb 9, 2006 | 08:04 AM
96TEGgSR07's Avatar
if anyone has anymore about this setup plz comment.
Old Feb 9, 2006 | 08:06 AM
IHateJDM's Avatar
there are about 4 threads in the first page of the hybrid forum you should read, and this one.
https://honda-tech.com/zerothread?id=1475661
Old Feb 9, 2006 | 08:33 AM
OHRides's Avatar
if you are set on a swap its more worth your time to do bseries
Old Feb 9, 2006 | 09:06 AM
96TEGgSR07's Avatar
Default Re: (OHRides)
how much does H2B cost??
Old Feb 9, 2006 | 09:46 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96TEGgSR07 &raquo;</TD></TR><TR><TD CLASS="quote">how much does H2B cost??</TD></TR></TABLE>
just under a grand.
89crxsleeper
Mar 17, 2007 03:07 PM
vtecspeed1320
Jan 27, 2006 09:38 PM
kev tec96
Jun 19, 2003 10:46 AM
