Are my compression test readings sky high?
D16a6 motor, ZC head, metal Z6 headgasket. This was my compression across the board. Just removed the #15 fuse, cranked the motor and went WOT and got these readings.
Too high? Did something wrong? 200+ across all four cylinders. Motor has 115K miles on it.
you might have some carbon build up try using some seafoam to clean it out and check numbers again...
215 it looks like from here??? isint a crazy high number but a little much for a stock sohc
i have a d15b vtec and i got 185 across the board... i wish i had 215
when i had the head off in december there was very little carbon buildup on the piston heads...i did scrape off a little bit with my finger but it was nothing really too bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeum4lyfe »</TD></TR><TR><TD CLASS="quote">you might have some carbon build up try using some seafoam to clean it out and check numbers again...
correct
correct
aj345
Jun 2, 2013 07:58 PM
stealth89hatch
16
Jun 19, 2005 10:37 AM
