ZC
Old Feb 8, 2006 | 01:14 PM
jdm91CrxSi's Avatar
Default ZC
will this fit in a 91 crx si http://www.hmotorsonline.com/s...30020
Old Feb 8, 2006 | 01:22 PM
EP3_05's Avatar
Default Re: ZC (jdm91CrxSi)
Yes it bolts right in to the civic/crx si with minimal work.
Old Feb 8, 2006 | 01:30 PM
jlicrx's Avatar
minor wiring change at distributor is all you need to do - plus get 88-89 integra upper radiator hose
Old Feb 8, 2006 | 02:15 PM
doberneckerj's Avatar
i have a 91 lx and i had 2 make a mount on the drivers side. but never figured out the distributer part. yet....
Old Feb 8, 2006 | 02:17 PM
CRX_DOHC_ZC's Avatar
http://thenew.gamesbbs.com/~dmoore/zc.htm
thats a good website
The upper radiator hose is from a 84 accord
Just check it out it will answer most questions
Old Feb 8, 2006 | 02:35 PM
jlicrx's Avatar
Default Re: ZC (doberneckerj)
you must not have a JDM 88-91 ZC - if you had to make mount, you probably have a USDM Integra D16A1, which is not a ZC and not even close
Old Feb 8, 2006 | 03:14 PM
Andrew Marquis's Avatar
Default Re: (CRX_DOHC_ZC)
G0 here and read every article.
The other guy linked you to it, but I just wanted to make sure you read look at it.
-Andrew
Modified by bakerboy4679 at 4:25 PM 2/8/2006
Old Feb 8, 2006 | 03:24 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_DOHC_ZC &raquo;</TD></TR><TR><TD CLASS="quote">http://thenew.gamesbbs.com/~dmoore/zc.htm
Just check it out it will answer most questions</TD></TR></TABLE>
that site is over 5 years old and has a lot of good information, but also has a a lot of bad information - yes, you can use 84 Accord upper hose if you want to cut it to make it fit <U>or</U> you can use 88-89 Integra which fits perfectly without cutting - i prefer the easy way
Old Feb 8, 2006 | 03:28 PM
jlicrx's Avatar
Default Re: (bakerboy4679)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bakerboy4679 &raquo;</TD></TR><TR><TD CLASS="quote">G0 here and read every article.
There is more involved than just installing an upper radiator hose and a distributor, if you want it to run right.
-Andrew</TD></TR></TABLE>
having done over 2 dozen DOHC ZC swaps in the last 7 years, i would have to say "you have a lot to learn about a ZC swap"
Old Feb 8, 2006 | 04:56 PM
Default Re: (jlicrx)
I'm positive you know more than me about them, mainly b/c you've acutally done them(a lot of them it seems), but I'm just saying that website is better than going at it blindly... wouldnt you agree?
Do you know of any better(newer) websites that would have more correct information?
I'd love to see some.
If you do, please PM me or jsut post them.
Thanks
-Andrew
Old Feb 8, 2006 | 07:41 PM
jlicrx's Avatar
http://www.thezcr.com
hrowell88
Transmission & Drivetrain
Apr 15, 2015 05:22 AM
02 coupe
Jun 5, 2005 04:57 AM
SpankyofNOLA
Dec 29, 2004 09:05 AM
spyz34
Mar 31, 2004 04:49 PM
GroundZer0
12
Aug 15, 2002 07:19 AM
