Just put B&M Fule Pressure Regulator and guage...
Old Feb 7, 2006 | 07:31 PM
QuickRexSi21's Avatar
Default Just put B&M Fule Pressure Regulator and guage...
what would be the best amount of pressure to have it on?
Old Feb 10, 2006 | 02:24 PM
Default Re: Just put B&M Fule Pressure Regulator and guage... (QuickRexSi21)
bump anyone
Old Feb 10, 2006 | 02:27 PM
eda6's Avatar
put the old fpr back on and check fuel pressure.
35-41 psi for b16 with vac hose off.
Old Feb 10, 2006 | 02:39 PM
Default Re: Just put B&M Fule Pressure Regulator and guage... (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">put the old fpr back on and check fuel pressure.
35-41 psi for b16 with vac hose off.</TD></TR></TABLE>
its a B&M so i had to cut the FPR at the top to fit it....dont have it anymore maybe i can use my friends. his hatch aint runnin anyways
right now its at 40 PSI with the hose on....
Old Feb 10, 2006 | 02:44 PM
eda6's Avatar
stock fuel pressure is 35-41 psi with the vacuum hose disconnected.
Old Feb 10, 2006 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">stock fuel pressure is 35-41 psi with the vacuum hose disconnected.</TD></TR></TABLE>
thank you. ill just leave it at that for daily driving
Old Feb 10, 2006 | 05:03 PM
xaine's Avatar
what i lways do when instaling these is go 1-3 psi over stock
and 1-3 psi under stock and see witch is best
i am running mine about 3 psi over stock
same b&m kit
buy a fuel rail and you can fit the gauge right on the fuel rail
Old Feb 10, 2006 | 05:15 PM
Default Re: Just put B&M Fule Pressure Regulator and guage... (xaine)
same b&m kit
buy a fuel rail and you can fit the gauge right on the fuel rail [/QUOTE]
that would look ****! where on the fuel rail can it go? i put it on the fuel Filter
Old Feb 10, 2006 | 05:23 PM
ripperbone's Avatar
heres mine with AEM rail, AEM FPR and no name pressure gauge
Old Feb 10, 2006 | 05:28 PM
Default Re: (ripperbone)
very NICE! i like that look better than the stock fuel rail
good B Series
Old Feb 10, 2006 | 06:54 PM
EF9ZC's Avatar
i would get rid of the b&m fuel regulator i lost atleast 5mpg by using it.
Old Feb 10, 2006 | 07:15 PM
Default Re: (EF9ZC)
too late for that now
Old Feb 10, 2006 | 09:47 PM
Mr_CRX's Avatar
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">i would get rid of the b&m fuel regulator i lost atleast 5mpg by using it.</TD></TR></TABLE>
What was your pressure on the stock FPR, and what did you set the B&M to? If you set the B&M to stock fuel pressure, it should have no negative effect on your gas mileage.
Old Feb 10, 2006 | 11:57 PM
Default Re: (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i was thinking, i just didnt wanna say it and be wrong, then all of a sudden i get ranted on
HatchBox
Mar 11, 2005 04:57 PM
hotimportcrx
Feb 4, 2005 08:31 PM
Mr.EM1
Jan 6, 2005 11:17 AM
Muckman
Dec 6, 2003 01:40 PM
TakaIntegra
Jun 18, 2002 06:30 AM
