i cant get my timing lower than 21* why??(dohc zc)
i just finished my zc re-build and i set my timing but the lowest i could go was 21* tdc........ when i installed the timing belt (the 2nd time) i set the cranks and cams(gears) at tdc and put the belt on everything, let the car warm up and hooked up a timing light at 1st the car was at 24* tdc.....then i retarded the timing (by moving the distributor) and the lowest i got was 21* and stock timing should be 16* + or - 2* help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">sounds like the camshaft timing is off 1 tooth</TD></TR></TABLE>would it be the cam shaft or cam gear(to timing belt)?
my guess is the intake cam is off - if exhaust was off, you would probably be getting CEL with code 9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">my guess is the intake cam is off - if exhaust was off, you would probably be getting CEL with code 9</TD></TR></TABLE>well i was getting a code 9 till i re-did my timing now im only getting a code 10 (which i didnt have before the rebuild)
luvs2spooge
May 18, 2007 05:42 PM
