My Setup---looking for a base program OBD0
I have a 91 CRX SI with:
81.5mm LS/VTEC
CTR Pistons
PR3 Head
12.68:1 compression with Cometic .040" Headgasket
Crower Stage 3 Cams/Valvetrain
Ported ITR Intake manifold
I/H/E
Venom 310cc injectors
Venom 255lph fuel pump
I have a PR3 ECU and I'm looking for a basemap. (CROME?)
I know the injectors and fuel pump may be a bit on the big side, but i think they may work because I met a kid with close to the same setup(skunk2 stage 2 cams) doing 206whp, but hes got an OBD1 Teg.
81.5mm LS/VTEC
CTR Pistons
PR3 Head
I/H/E
check this sites.
http://www.pgmfi.org/
http://www.ecucontrol.com/
Or if you want to use crome then you will have to convert to obd-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdocrx »</TD></TR><TR><TD CLASS="quote">just use bre. great program, no bugs, worked well for my car.</TD></TR></TABLE>
BRE looks good, i know TE had many bugs a year ago and it seems development is dead. so i went obd0 and crome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSV_REX »</TD></TR><TR><TD CLASS="quote">never even heard of BRE.</TD></TR></TABLE>
You betta rekonize! For obd0 vtec, BRE >> * Ben is the man, he's got a great app going, and a PR3 is the "right" way to do it. 4 maps > 2. Plus all the other badass stuff it's got. Mmmmmm... Autotune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">
Listen to this man!
</TD></TR></TABLE>Listen to this man!
u can start it, ubt what your afrs, maybe adjust the map with a correction factor of like 5% and dont beat on it. Get it running no problems, then goto the dyno and watch those afrs.
Did you ever get the datalogging worked out?</TD></TR></TABLE>
No.
Did you ever get the datalogging worked out?</TD></TR></TABLE>No.
You betta rekonize! For obd0 vtec, BRE >> * </TD></TR></TABLE>
werd. Now if I can just get people to stop converting to obd1. Its not necessary most of the time!!
Ben
You betta rekonize! For obd0 vtec, BRE >> * </TD></TR></TABLE>werd. Now if I can just get people to stop converting to obd1. Its not necessary most of the time!!
Ben
Never fear, I'll be putting a PR3 in my friends ls-vtec CRX, and BRE will handle my dirty work. Unless you've got a really ridiculous car and have some problem you need the special features of Crome to solve, OBD0 is the way to go.
lance_ecl
Apr 8, 2007 11:03 AM
kingkong
May 9, 2005 11:19 PM
