Replacement Radiator
My radiator started leaking from the top, which appears to be fairly common. So, I ordered a replacement Koyo unit online.
I just received it, and there appear to be 2 additional, smaller hose fittings. One next to the lower radiator hose and the other on the driver's side. It doesn't look like the stock radiator has these 2 fittings.
Did I get the wrong radiator?
The fittings have rubber caps on them. Am I supposed to use it with the rubber caps to block off the fittings? This seems like another source for a future leak...
Any help is appreciated. Thanks!
that should be correct on my 96 Civic when I bought a RAD for it it had those 2 additional fittings they should just be capped off.. They never leaked for me
I was thinking they sent me a radiator for an automatic trans car....
Anyone strongly suggest I get one specific for manual trans car? Otherwise, I'm going to install it tomorrow afternoon.
Thanks everyone.
Thanks everyone.
mine was like that too when I recieved it. I guess its some what universal to be used for auto or manual. I basically plugged/capped off those additional hose fittings or whatever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">why does everybody plug these? if there's no fluid going through there, what's the difference if they're plugged or open?</TD></TR></TABLE>
Fluid does go there unless you plug it. Aftermarket radiators (for the most part) have those extra 2 fittings and unless you plug them, coolant will flow through them as well.
I ordered a radiator for my integra and it came with this **** to on the bottom. I took them off and nothin leaks out of them so I am with you on this one.
There is seperate tanks, it won't leak, no need to cap, seal, plug, blah, blah, blah. That would be a pretty crappy design if the auto tranny fluid went to those lines and was mixed with coolant, think about it.
BoostedH23Accord
Transmission & Drivetrain
Nov 14, 2009 08:40 PM
