Replacement Radiator
Old Feb 7, 2006 | 01:16 PM
lightsped2's Avatar
Default Replacement Radiator
My radiator started leaking from the top, which appears to be fairly common. So, I ordered a replacement Koyo unit online.
I just received it, and there appear to be 2 additional, smaller hose fittings. One next to the lower radiator hose and the other on the driver's side. It doesn't look like the stock radiator has these 2 fittings.
Did I get the wrong radiator?
The fittings have rubber caps on them. Am I supposed to use it with the rubber caps to block off the fittings? This seems like another source for a future leak...
Any help is appreciated. Thanks!
Old Feb 7, 2006 | 01:24 PM
Civicracer17's Avatar
Default Re: Replacement Radiator (lightsped2)
that should be correct on my 96 Civic when I bought a RAD for it it had those 2 additional fittings they should just be capped off.. They never leaked for me
Old Feb 7, 2006 | 04:15 PM
DirtyBirdJR's Avatar
its for an auto car you can use it for an oil cooler if you want
Old Feb 7, 2006 | 04:58 PM
lightsped2's Avatar
Default Re: Replacement Radiator (DirtyBirdJR)
I was thinking they sent me a radiator for an automatic trans car....
Anyone strongly suggest I get one specific for manual trans car? Otherwise, I'm going to install it tomorrow afternoon.
Thanks everyone.
Old Feb 7, 2006 | 05:06 PM
iH8RICERZ's Avatar
mine was like that too when I recieved it. I guess its some what universal to be used for auto or manual. I basically plugged/capped off those additional hose fittings or whatever
Old Feb 7, 2006 | 05:52 PM
LSvtec03's Avatar
Default Re: Replacement Radiator (iH8RICERZ)
why does everybody plug these? if there's no fluid going through there, what's the difference if they're plugged or open?
Old Feb 7, 2006 | 06:58 PM
Wayne_Curr's Avatar
Default Re: Replacement Radiator (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">why does everybody plug these? if there's no fluid going through there, what's the difference if they're plugged or open?</TD></TR></TABLE>
Fluid does go there unless you plug it. Aftermarket radiators (for the most part) have those extra 2 fittings and unless you plug them, coolant will flow through them as well.
Old Feb 13, 2006 | 03:16 PM
Tim.'s Avatar
are the rubber plugs that come on the rad. good enough to plug them?
Old Feb 13, 2006 | 04:48 PM
kevs_92gsr's Avatar
I ordered a radiator for my integra and it came with this **** to on the bottom. I took them off and nothin leaks out of them so I am with you on this one.
Old Feb 13, 2006 | 04:55 PM
Sam92Teg's Avatar
Default Re: Replacement Radiator (kevs_92gsr)
There is seperate tanks, it won't leak, no need to cap, seal, plug, blah, blah, blah. That would be a pretty crappy design if the auto tranny fluid went to those lines and was mixed with coolant, think about it.
Old Feb 13, 2006 | 04:57 PM
erikiksaz1's Avatar
Default Re: Replacement Radiator (Sam92Teg)
Indeed, just leave them alone, nothing will make it through.
BoostedH23Accord
Transmission & Drivetrain
Nov 14, 2009 08:40 PM
lmike6453
Oct 14, 2008 02:03 PM
stripery2bk
Apr 11, 2006 10:02 AM
vtecmw
Dec 5, 2005 09:44 AM
HatchBox
Apr 15, 2004 06:26 PM
