will a hydro clutch work for a cable
Old Feb 7, 2006 | 01:12 PM
Beau Gotti's Avatar
Default will a hydro clutch work for a cable
jw wondering im pretty sure it will just double checking before i buy it
Old Feb 7, 2006 | 01:14 PM
jlicrx's Avatar
Default Re: will a hydro clutch work for a cable (Beau Gotti)
yes, the clutch and pressure plate will work, but if you are buying a kit, the throwout bearings are different
Old Feb 7, 2006 | 09:48 PM
deucedeuceEK's Avatar
Default Re: will a hydro clutch work for a cable (jlicrx)
Sweeet so the disk and pressure plate for a hydro tranny will work in a cable fine? So would you buy the clutch allignment tool for a cable tranny also along with the throw out bearing and everything will be ok? Im also wondering because I can get an act disk and pressure plate from a friend cheap.
Old Feb 7, 2006 | 10:00 PM
EF8IGHT's Avatar
Default Re: will a hydro clutch work for a cable (EF-LS-HATCH)
NOPE! I dont think so, the spline on a cable trans is smaller than one on a hydro,
thats why they sell 90-93 integra clutches seprate from 94+
i know this cus i bought a clutch that was ment for a hydro trans for my 1st gen b16a swap and was very disapointed when it didnt fit.
Old Feb 27, 2006 | 07:45 PM
Crx Jimmy's Avatar
alright time for some proper info the pressure plate is the same, the thowout bearing is different, the disc will work for ys1 92-93 trans, 90-91 trans need a different disc, they are not the same it has a smaller splined center
Old Feb 27, 2006 | 07:48 PM
Slow ass EF's Avatar
Default Re: will a hydro clutch work for a cable (EF8IGHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8IGHT &raquo;</TD></TR><TR><TD CLASS="quote">NOPE! I dont think so, the spline on a cable trans is smaller than one on a hydro,
i know this cus i bought a clutch that was ment for a hydro trans for my 1st gen b16a swap and was very disapointed when it didnt fit.</TD></TR></TABLE>
MY 94 LS clutch wouldnt work in my friends 90 LS trans...
Old Feb 27, 2006 | 07:53 PM
STREETWERKZ's Avatar
Default Re: will a hydro clutch work for a cable (Slow *** EF)
they are the same....
although you shouldnt believe everything you read on the internet...
i have personally installed a 92-95 civic into a 89-91 civic trans.
what these fellows tell you is true. (throwout bearing/release bearing)
Old Feb 27, 2006 | 09:40 PM
HandCommand's Avatar
Default Re: will a hydro clutch work for a cable (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">alright time for some proper info the pressure plate is the same, the thowout bearing is different, the disc will work for ys1 92-93 trans, 90-91 trans need a different disc, they are not the same it has a smaller splined center</TD></TR></TABLE>
This guy is right, but I will go more into detail.
All B-series trannys from 92+up will use the CLUTCH DISC with the Bigger spline.
The 90-91 B-series trannys will use the CLUTCH DISC with the smaller spline, because they have a smaller input shaft.
All B-series Pressure Plates will be the same no matter if its CABLE or Hydro.
ThrowOut Bearings will be different between a CABLE tranny and a HYDRO tranny.
It amazes me to see how much MisInformation is spread on Honda-Tech! And then on top of that, you have people re-posting or agreeing to the wrong information misleading even more people!
hammergunner
Aug 31, 2008 01:23 AM
Seminole
Feb 22, 2008 08:32 AM
MHBb16CRX
Jul 18, 2007 05:14 AM
g2_teg_
Dec 15, 2005 06:46 PM
spidermancivic
May 1, 2005 08:31 PM
