Code 21 randomly, solenoid works, what's the deal?
Old Feb 7, 2006 | 07:04 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Code 21 randomly, solenoid works, what's the deal?
CEL codes a 21 usually once or twice a day, once to work and once back. I turn the car off and back on again and it goes away. I haven't cleared (unplugged) my ECU yet so I'll try that at lunch. Solenoid works I gave it 12volts and it switches.
Could this be a trash in the filter therefore not enough oil pressure problem or a half faulty vtec solenoid...etc?
Any help would be great.
Chris
Old Feb 7, 2006 | 07:45 AM
Rory Breaker's Avatar
Default Re: Code 21 randomly, solenoid works, what's the deal? (DAantagonist)
I had this problem for a while. Cleaned off the harness connectors and it went away.
Old Feb 7, 2006 | 08:35 AM
Default Re: Code 21 randomly, solenoid works, what's the deal? (Rory Breaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rory Breaker &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem for a while. Cleaned off the harness connectors and it went away.</TD></TR></TABLE>
no kidding, I just wired in a plug for the vtec oil pressure switch (two wire plug). I'll check the connection/contacts on that (it should be FINE since it's a new plug) as well as on the vtec solenoid and see if there's an issue. Thanks for the input.
Chris
Old Feb 7, 2006 | 11:14 AM
anyone else?
Old Feb 8, 2006 | 05:44 AM
cleaned wires/connections still same problem...anyone else?
Old Feb 8, 2006 | 08:27 AM
holy shizzle...no one else?
Old Feb 10, 2006 | 05:13 AM
ok I have done the following..
checked continuity between ecu and solenoid (there is)
check resistance of solenoid (14-30ohms range) it reads 14.7
changed vtec solenoid to one that reads 18.4ohms
this morning I unplugged the ecu checked the wiring again...funny thing is, now it doesn't throw the code...
anyone else got any ideas...the things I have done are straight out of helms trouble shooting...if it codes again, the last thing I can do is try another ECU...
ejalex
Sep 14, 2012 11:25 PM
LSracing94
17
Aug 7, 2006 10:00 AM
ProjectEGSiR
May 24, 2006 12:40 PM
IlIkEg's
Nov 15, 2005 11:22 PM
type Gendy
107
May 6, 2004 09:10 PM
