Valve seals
Old Feb 7, 2006 | 06:25 AM
r1de4life's Avatar
Default Valve seals
How hard is it to replace valve seals? or what? and what do u have to do?
Old Feb 7, 2006 | 09:02 AM
kulrevon's Avatar
Default Re: Valve seals (r1de4life)
either on the car or off the car it is somewhat difficult.
If it is on the car you would need to do the string trick or compress the cylinder, or fill the chamber with a rag. this is done so you dont drop the valve into the chamber.
you would need a valve spring compressor which can be purchased or made. you would need an in car valve spring compressor if you are doing it while the head is on the block.
I would not say it is the easiest of jobs.
nomoshing
Jan 20, 2009 10:35 PM
Dxs
Jun 12, 2008 09:29 PM
BoostdRex
Jul 30, 2007 07:07 AM
RedRacerCivic
Jul 11, 2002 12:19 AM
speedymon
Jan 23, 2002 01:29 PM
