In VA & got a valve spring compressor?
Old Jan 23, 2002 | 05:14 AM
speedymon's Avatar
Default In VA & got a valve spring compressor?
Anyone in Va got a valve spring compressor i can borrow? Or any ideas on how to replace valve springs without one would be nice. Also when replacing the retainers, can i reuse the keepers?
Old Jan 23, 2002 | 08:17 AM
porch's Avatar
New User
Default Re: In VA & got a valve spring compressor? (speedymon)
Just want to tag on here with a near similar question.
I'm thinking about buying a valve spring compressor so I can replace the valve seals on my car myself. But I don't want to pull the head off. You have to pump air into the spark plug hole to keep the vavles from falling into the cylinder. Has anyone done this? What did you use to pump air in the cylinder? I don't have an air compressor, so I may be screwed. Just curious if anyone has done it, their experience, and any gotchyas I should look out for.
Note: I have the helms manual and a general inclination for things mechanical.
Old Jan 23, 2002 | 08:20 AM
speedymon's Avatar
Default Re: In VA & got a valve spring compressor? (porch)
I thought the valve seals were the metal rings inside of the cylinder that rested on the valve. They're made out of steel right?
Old Jan 23, 2002 | 08:40 AM
sgT's Avatar
sgT
speedymon: those are valve SEATS
You cannot change the valve stem/guide seals with the head on the car.
(well i suppose you can but it would take FOREVER and be near impossible)
You should remove the valve to change the seals.
Old Jan 23, 2002 | 08:42 AM
speedymon's Avatar
Default Re: In VA & got a valve spring compressor? (sgT)
thats what i mean't
Old Jan 23, 2002 | 12:20 PM
porch's Avatar
New User
The helms manual lays the procedure out to change the valve seals with the head on the car. But it does look a lot simpler with the head off.
page 6-5 if you have one in front of you.
[Modified by porch, 1:20 PM 1/23/2002]
Old Jan 23, 2002 | 01:19 PM
rainforest's Avatar
all you have to do to take them off is use a 12-16mm sockest w/extension and a hammer and whack the top of the retainer. the valve guides will just fall out. you will have to get a special snap-on specialty tool for the the install. most of the valve spring compressors are to big and cant fit in the head.
Old Jan 23, 2002 | 01:22 PM
sgT's Avatar
sgT
Default Re: In VA & got a valve spring compressor? (rainforest)
guides wil fall right out?
dont you mean the valve locks/keepers?
You dont want to do that with the head on the car, you have a great chance
to lose them.
Old Jan 23, 2002 | 01:26 PM
rainforest's Avatar
iam a *** vlave keepers. nah man i allways take the head off while doing valves.-
Old Jan 23, 2002 | 01:29 PM
martini's Avatar
BTW, it's not too difficult to make your own valve spring compressor..
Dxs
Jun 12, 2008 09:29 PM
r1de4life
Feb 7, 2006 09:02 AM
mycrx7
Sep 22, 2005 08:03 PM
JunIntegra
Apr 11, 2003 05:15 PM
RedRacerCivic
Jul 11, 2002 12:19 AM
