Need help on install catch can on B20Vtec turbo
Old Feb 6, 2006 | 12:12 PM
CRX 2.0V-T's Avatar
Default Need help on install catch can on B20Vtec turbo
Hi like the title said i need help on install the catch can on B20 vtec turbo.
Here is my story, as every1 know that there is the black box behind the GSR block (PCV chamber) and the B20 there is none, so when i converted to B20/Vtec i didnt know what it was or either the use of it so i threw it away (which is so stupid), and now i have only the hose that run from intake mani to the PCV chamber open loose. Then i turbo this setup.
Here is my question,
1. Would this (not having pcv system) cause the problem that it makes alot of smoke coming out my exhaust?
2. How bad is it if i dont have it? or can i run without it?
3. How do i install the catch can for this (i searched and found some but it was for B18C, would it be the same?) and the way to install it doesnt need the pcv chamber.
SlowB20z
Feb 18, 2013 09:06 AM
G_moneydc2
Feb 23, 2006 05:52 PM
coupedup
May 10, 2002 07:33 PM
turbocoupe
Oct 22, 2001 09:47 PM
