Gsr vs. Si tranny in a LSVTEC
Old Feb 6, 2006 | 11:37 AM
7mile's Avatar
Default Gsr vs. Si tranny in a LSVTEC
I have a gsr in my lsvtec right now, and wanted to get shorter gears.
Will the b16a2 tranny hold power for the lsvtec?
I heard it will wear down and gear eventually expletive up on the long run?
Need advice thanks.
Old Feb 6, 2006 | 11:47 AM
cdnB18C1's Avatar
Default Re: Gsr vs. Si tranny in a LSVTEC (7mile)
I have an Si tranny in my GSR, and i don't know about future problems but its still running fine.
Im assuming that it there should be no horsepower related issues considering the Si stats say 160 hp, and the GSR at 170 (im assuming LSVTEC would be the same)
Old Feb 6, 2006 | 12:30 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Gsr vs. Si tranny in a LSVTEC (cdnB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdnB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">I have an Si tranny in my GSR, and i don't know about future problems but its still running fine.
Im assuming that it there should be no horsepower related issues considering the Si stats say 160 hp, and the GSR at 170 (im assuming LSVTEC would be the same)</TD></TR></TABLE>
I have a YS1 GSR trans on lsv....there will be no problems with whatever trans you choose. At least that I've ever heard of.
Old Feb 6, 2006 | 04:56 PM
Vtecme92's Avatar
Default Re: Gsr vs. Si tranny in a LSVTEC (DAantagonist)
its up to you I have a si tranny in my I use to have a ls tranny..the si tranny is alot better for me and I notice the difference but between si and gsr i don't think it would be that much of a difference
Old Feb 6, 2006 | 06:03 PM
mattcivic's Avatar
Default Re: Gsr vs. Si tranny in a LSVTEC (Vtecme92)
i had an ls/vtec with a gsr tranny i blew it up and got me a b16 tranny i loved the gsr tranny a good mix beetween racing and casual driving.
Old Feb 6, 2006 | 06:26 PM
Z32Z06's Avatar
Default Re: Gsr vs. Si tranny in a LSVTEC (mattcivic)
it all depepnds on what you want it for
the B16 tranny willl have shorter gears then the GSR
so it all depends on what you are looking for
Old Feb 6, 2006 | 07:41 PM
H23 Power's Avatar
why not just get a 4.7x or 4.9x final drive for the GSR tranny?
Old Feb 6, 2006 | 08:53 PM
Rikter's Avatar
Get the SIR tranny from japan (S1). Tight gears. Me lovey it on my LS/Vtec. Going to be insane on my turbo ls/vtec
-Rik
Old Feb 10, 2006 | 09:06 AM
7mile's Avatar
yeah true...i like the short gears more..
Old Feb 10, 2006 | 09:26 AM
bottom line is this...
if you track your car only, then get the shortest geared trans you can find...which I think is a ITR trans or a YS1 GSR cable trans
otherwise, go with a Si trans for the short gearing and a longer 5th gear for cruising...5k@ 80mph is a pain in the ***...keeps me from speeding too much though. Honestly, I'd kill for a LS 5th gear lol...
Old Feb 10, 2006 | 10:41 AM
95TegSE's Avatar
I thought the b16 and ITR trans were geared exactly the same.
Old Feb 10, 2006 | 10:44 AM
Default Re: Gsr vs. Si tranny in a LSVTEC (95TegSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">I thought the b16 and ITR trans were geared exactly the same.</TD></TR></TABLE>
EDIT...
did a few minutes of research and you're right...my fault.
Modified by DAantagonist at 3:08 PM 2/10/2006
Old Feb 10, 2006 | 11:06 AM
use this link:
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
nengx07
14
Feb 12, 2009 11:08 PM
touintegra1
May 8, 2006 07:18 PM
bulori
Aug 14, 2003 03:06 PM
Forgiven
Feb 20, 2003 11:44 AM
TeamTooQuick
May 15, 2002 05:51 AM
