some insight... tie rod part i think
Old Feb 6, 2006 | 10:57 AM
the soL that could's Avatar
Default some insight... tie rod part i think
**** i have a problem... happens everytime i inspect my car. LoL
in the picture below, the parts i have circled are torn into pieces. i believed that was to be the steering rack, but the hondaparts page listed them not part of the rack so i was confused... now i called the dealership and they told me tierod dust boot which made a little happier because it saved me 400$. should i replace them dust boots? or leave it alone?
Modified by the soL that could at 2:58 PM 2/7/2006
Old Feb 6, 2006 | 11:27 AM
eboostedg's Avatar
Default Re: some insight... tie rod part i think (the soL that could)
replace them, cheap easy fix might as well
Old Feb 6, 2006 | 11:35 AM
ZipTieGUy's Avatar
well in my opinion if it aint causing a problem i just leave it alone
Old Feb 6, 2006 | 11:45 AM
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eboostedg &raquo;</TD></TR><TR><TD CLASS="quote">replace them, cheap easy fix might as well</TD></TR></TABLE>
really don't know how. lol **** looks more complicated that an engine swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">well in my opinion if it aint causing a problem i just leave it alone</TD></TR></TABLE>
yeah that's what i was thinking too. but i really want to do something about it. might get so much crap in there that it might turn into a problem. my steering is really sensitive. itat first i thought it was jacking up my turns because it's responsive ... but then i realized it's lighter lighter than the 00 accord i drive daily sooo it should be like that.
Old Feb 7, 2006 | 01:33 PM
snatch's Avatar
Pic don't work dude.
If the dust boot is ripped on the tie rod end replace it. Dirt will just get in there and the grease will leak out, if it hasn't already, and then the tie rod end will go to ****. Replace it.
Old Feb 7, 2006 | 01:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Pic don't work dude.
If the dust boot is ripped on the tie rod end replace it. Dirt will just get in there and the grease will leak out, if it hasn't already, and then the tie rod end will go to ****. Replace it.</TD></TR></TABLE>
i have no more grease in there. lol it just looks dirty. i was thinin about just changing the tirerod and the boot. how easy is this?
Old Feb 7, 2006 | 02:51 PM
Marauder's Avatar
Yeah, don't spend $40 on new boots, instead let dirt and water get into your steering rack until it goes bad and you spend $$$hundreds instead.
Not too smart.
Old Feb 7, 2006 | 02:52 PM
Marauder's Avatar
Default Re: (the soL that could)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the soL that could &raquo;</TD></TR><TR><TD CLASS="quote">
i have no more grease in there. lol it just looks dirty. i was thinin about just changing the tirerod and the boot. how easy is this?</TD></TR></TABLE>
Its not too easy for someone doing it for their first time. But it'll save you a bunch of money in the long run, cause if you don't you'll have to replace your steering rack eventually.
Old Feb 7, 2006 | 03:09 PM
i bought this car used so i don't even know how long this **** has been out for. it steers fine right now. i was thinking about changing out the tie rods and the boots while i was at it.
Old Feb 7, 2006 | 06:22 PM
EvilPhu's Avatar
change them both (tie rod and boot), it's not a hard of a job. Just remeber to put the new tie rod at the same position, mark it or count the thread. After that an alignment is needed. I think the rod are like 65 each. So it may cost like 250
Old Feb 7, 2006 | 06:38 PM
ABK's Avatar
ABK
yeah those are called dust boots (below boots). Yes replace them ASAP unless you want the seals to get eaten by the dirt on the rack, and that **** will start leaking.
Before you start taking **** apart, mark the tire rods where they join, so don't throw your alligment off by much. I suggest getting one done anyways after the install.
Old Feb 8, 2006 | 04:32 AM
snatch's Avatar
Default Re: some insight... tie rod part i think (ABK)
I just replaced mine a few months back. It was ~$50 for both in parts, and it took me about 45 minutes from start to finish.
Search on here for tie rod replacement, you will find a few DIY how-to's. It's really not that hard. But you should get an alignment afterwards.
Old Feb 8, 2006 | 06:23 AM
jaypanEG6's Avatar
Default Re: some insight... tie rod part i think (******)
mine have been ripped for pver a year now, i have the parts to replace them, im just waiting for a sign...nothing yet in over a year..
Old Feb 8, 2006 | 07:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaypanEG6 &raquo;</TD></TR><TR><TD CLASS="quote">mine have been ripped for pver a year now, i have the parts to replace them, im just waiting for a sign...nothing yet in over a year.. </TD></TR></TABLE>
a sign... it's going to just drop off when you're driving. j/k. just wanna get this sucker back into good shape before i insure it and drive.
baiwldrnner
Honda Civic (2001 - 2005)
Aug 7, 2007 09:32 AM
SiYouLater
Aug 3, 2007 08:25 PM
kaj
May 14, 2007 03:42 PM
the soL that could
Suspension & Brakes
Feb 14, 2006 02:18 PM
the soL that could
Suspension & Brakes
13
Feb 8, 2006 07:39 AM
