Need Help!! Noob questions but a valid one
Old Feb 6, 2006 | 10:06 AM
mkim0801's Avatar
Default Need Help!! Noob questions but a valid one
Okay, I've searched the archives and couldn't find an answer. My radiator hose leaked fluid on the speed sensor and now my speedometer is not working. As expected my ecu is throwing up a code 17. I have ordered a new sensor but how can I check to see if the connector is okay? If the connector is the problem, can I just cut the damaged connector out and splice a new connector in or do I need to replace the entire wiring? Also what can I do to clean the connector? Any particular cleaner to use? Where can I find a new connector? Price range? Is there a DIY on this? Any links would be appreciated. BTW, I have a 95 Civic EX coupe.
Old Feb 6, 2006 | 11:49 AM
Baggy Spandex's Avatar
Default Re: Need Help!! Noob questions but a valid one (mkim0801)
It's most likely the sensor itself...the connector should be okay.
I would also change the tranny fluid just in case. The outlet for that sensor goes directly into the transmission. Even though the chances of some coolant getting in there and doing any kind of damage is slim to none, id still do it as a precaution
Old Feb 6, 2006 | 11:55 AM
mkim0801's Avatar
Default Re: Need Help!! Noob questions but a valid one (NAisBEST)
Thanks for your help. I'll be sure to change the fluid once I replace the sensor.
DisplacedMic
Jul 27, 2016 12:33 PM
FZS Chad
Jun 28, 2012 10:40 PM
BanEL
Jun 4, 2009 06:07 AM
pennies_hatchie
14
Oct 31, 2002 08:49 AM
