Can I use a OBD0 plug on a OBD2 dizzy?
Old Feb 5, 2006 | 10:57 AM
NACvicSi's Avatar
Default Can I use a OBD0 plug on a OBD2 dizzy?
Like the title says, I need to know if I can cut my obd0 dizzy plug off, solder it on to my OBD2 dizzy, and plug it into my stock harness and it work fine with my P28?
Old Feb 5, 2006 | 11:28 AM
SVOboy's Avatar
That's my plan/bump cuz I'm not sure.
Old Feb 5, 2006 | 12:05 PM
theinfamouskonrad's Avatar
Default Re: (SVOboy)
Yes it will work fine. I do it all the time while converting to obd1. Pretty simple to figure out.
Old Feb 5, 2006 | 12:08 PM
SVOboy's Avatar
Thanks, that's what I guessed.
Old Feb 5, 2006 | 12:44 PM
NACvicSi's Avatar
thanks man. And thanks SVOboy for the good deal on the P28!
Old Feb 5, 2006 | 01:18 PM
SVOboy's Avatar
Just get your damn swap done,
Old Feb 18, 2006 | 05:25 PM
beyondspexj's Avatar
so for instance if i was to keep my stock si motor in my civic and switch over to obd1 i can use the obd2 dizzy? or what dizzy would i use on the A6 when going obd1?? i know how to do everything else..
Old Feb 18, 2006 | 05:29 PM
Malgerus's Avatar
Default Re: (beyondspecs_jamar)
The OBD O, I, and II distributors/harnesses have the same number of wires. A plug is just a plug; you can cut and solder any plug on there you want, just make sure it matches.
Old Feb 18, 2006 | 05:59 PM
SVOboy's Avatar
OBD1 and OBD2 dizzies can both be used with obd1,
Old Feb 18, 2006 | 06:16 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 and OBD2 dizzies can both be used with obd1, </TD></TR></TABLE>
Correct!
And what's even nicer is that all wire colours should match between the 3 generations (if I remember correctly).
Old Feb 18, 2006 | 06:41 PM
what im mainly conserned with is bolting it to the head with no modification to the "legs"
Championship
Nov 24, 2010 05:45 PM
sumoneEK
Aug 2, 2010 09:29 AM
DA3DC2
Jan 9, 2010 06:41 PM
pcguy760
Apr 25, 2005 06:54 AM
gezer
Aug 26, 2004 10:42 PM
