Wal-Mart Oil Filter
It's sunday and my oil is about 2500 miles past due for a change. All the dealerships are closed and I can't get my hands on a honda filter, will the wal-mart filters make due??, or should I simply wait till next weekend and get a genuine honda filter like I always do. Any help would be appreciated.
I use Mobil 1 which you can get from Autozone, dont use the Honda ones anymore since the retarded sizing and manufactuer choice.
Others will prob chime in with all the Bob the oil guy forum stuff about purolator or whatever. Does it really matter? :
Fram has some nice stuff too. [EDIT: By nice, I mean sucky.]
But Koala Yummies has a point, http://www.bobistheoilguy.com
Modified by Chris F at 12:18 PM 2/6/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">I use Mobil 1 which you can get from Autozone, dont use the Honda ones anymore since the retarded sizing and manufactuer choice.
:</TD></TR></TABLE>
Agree. Just go to any autoparts store and buy either K&N or Mobil filter..
:</TD></TR></TABLE>Agree. Just go to any autoparts store and buy either K&N or Mobil filter..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">Fram has some nice stuff too.</TD></TR></TABLE>
Since when?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">But Koala Yummies has a point, http://www.bobistheoilguy.com</TD></TR></TABLE>
Good boy, Chris.
SuperTech filters are a good deal for $2.07. Have no fear.
Since when?
Good boy, Chris.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surprise! You’re Dead! »</TD></TR><TR><TD CLASS="quote">
SuperTech filters are a good deal for $2.07. Have no fear. </TD></TR></TABLE>
as much oil as mine drinks i was thinking about getting some supertech oil... .87 cents a quart.... any epinions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">It's sunday and my oil is about 2500 miles past due for a change. All the dealerships are closed and I can't get my hands on a honda filter, will the wal-mart filters make due??, or should I simply wait till next weekend and get a genuine honda filter like I always do. Any help would be appreciated.</TD></TR></TABLE>
how often do you change your oil? techically you could go w/ same filter per 2 oil changes.. i do that, but my oil change intervals are shorter.. every 2.5k-3k per oil change
From: With my POS D15B2, Whereever whenever, United States
As long as you change your oil all the time, the oil filter doesn't really matter.
I've used supertech filters on a 99 SI and now on a MKIV TT 6 spd, and its the same ****.
Oil on the other hand matter, Royal Purple FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Surprise! You’re Dead! »</TD></TR><TR><TD CLASS="quote">Since when?</TD></TR></TABLE>
yeah, you're right.
A friend of mine's website:
http://minimopar.knizefamily.n....html
yeah, you're right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">is purolator pure one any good?
Premium Plus L30001
Left to Right: Motorcraft, Purolator Pure One, Purolator Premium Plus
Here is a fairly well designed filter, especially for the price. One odd thing about Purolator's filters is a string that is always wrapped around the filter element. I assume that this is there to hold the element in place while the glue in the end caps cures. Of all the Purolator-based filter I tested, there was one (the ProLine) that had filter element damage from this string. Although it was one of five tested, I am weary of this design. Even though the element was crushed a bit, it was not ripped.
The filter cartridge has an impressive surface area of 316 sqin, which is very close to the AC Delco Duraguard. The difference is that Purolator's filter element is compressed into more pleats (51) than the AC Delco. This may restrict flow somewhat, but not as much in this model than the Pure One. It features a spring-loaded metal bypass valve and a nitrile rubber diaphram-type anti-drainback valve, which doubles as the seal between the backplate and the cartridge. Like the Champion, this bypass valve is stamped right into the bottom end cap of the cartridge, so it is all one piece.
The telltale sign for a Purolator filter are: 8 medium-sized holes for the oil inlet and nothing but a black (or orange for the Pure One) diaphragm to be seen through them. There are 6 large crimps holding the gasket in place. Through the center outlet hole, you can see the spring for the bypass valve.
Exploded view:
Average Retail Price $3
Cartridge Length 4.125 inches
Cartridge Outside Diameter 3.250 inches
Cartridge Inside Diameter 1.625 inches
Cartridge Pleats 51
Cartridge End Cap Type Stamped-steel
Anti-Drainback Valve Type Nitrile rubber diaphragm
Bypass Valve Type Spring-loaded steel
Element Type Paper media, stamped metal seam
Element Length 79.0 inches
Element Width 4.000 inches
Element Surface Area 316 square inches
Shell Thickness 0.011 inches
Backplate Thickness 0.115 inches
Gasket Type Nitrile rubber
Pure One PL30001
This filter has a few improvements over the Premium Plus. It has a denser synthetic filter media to filter out smaller particles and more surface area to make up for the flow restriction. Aside from those the cartridge is the same construction as the Premium Plus.
The filter cartridge has an even more impressive surface area of 400 sqin. The potential issue is that this filter element is compressed into even more pleats (64) than the Premium Plus. This may restrict flow more than it helps relieve it, but it is hard to say for sure. It also features a spring-loaded metal bypass valve and a silicone rubber diaphram-type anti-drainback valve, which doubles as the seal between the backplate and the cartridge. The bypass valve is located at the base of the cartridge, not at the top.
Average Retail Price $5
Cartridge Pleats 64
Anti-Drainback Valve Type Silicone rubber diaphragm
Element Type Synthetic media, stamped metal seam
Element Length 100.0 inches
Element Surface Area 400 square inches
Gasket Type Nitrile rubber, PTFE-treated
Premium Plus L30001
Exploded view:
Cartridge Pleats 51
Pure One PL30001
Cartridge Pleats 64
Go with K&N or Mobile One. K&N is a little more but it has the nut on the end..so its never a hassle breaking a tight filter loose.
-Dan
-Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo »</TD></TR><TR><TD CLASS="quote">i've read somewhere that the mobil1 filter is ok at best, K&N on the other hand is
Pretty much, but like Chris has pointed out...it begins to be a very emotional, and personal decision.
I like the K&N for the same reason previously mentioned, the nut on the end.
Yes, I know you can get the "sockets" for the ends of the filters, but I still prefer the nut on the end of the K&N.
</TD></TR></TABLE>Pretty much, but like Chris has pointed out...it begins to be a very emotional, and personal decision.
ill tell you what,
what ever your choice,.. ill hold you hand all along the way..
ill tell you what,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">
ill tell you what,
Haha, thanks for the kind words dick
ill tell you what,
</TD></TR></TABLE>Haha, thanks for the kind words dick
