cel problem
Old Feb 5, 2006 | 06:18 AM
musTerdh22eg's Avatar
Default cel problem
so i get a cel after a few minutes of driving, i went to autozone cause they check it for free and the machine said linking error. ok, so i go down the street to jiffy lube cause i used to work there and i know they also have an obd2 scanner, so i borrowed it and i got the same result. what could be the problem?
Old Feb 5, 2006 | 07:13 AM
Default Re: cel problem (myb16civic)
any ideas?
Old Feb 5, 2006 | 10:30 AM
no one?
Old Feb 5, 2006 | 11:50 AM
wtf
Old Feb 5, 2006 | 12:10 PM
rafimos's Avatar
how many times did you try it?..i get the same thing sometimes, but i just turn the key off and let it sit a second, then do it again
for some reason its gotta take a min to read before you try to get it to link
Old Feb 5, 2006 | 12:21 PM
Default Re: cel problem (rafimos)
tried like 4 times with same result
Old Feb 5, 2006 | 01:46 PM
bump for another answer?
Old Feb 5, 2006 | 06:23 PM
rafimos's Avatar
what kind of scanner is it?
Old Feb 5, 2006 | 08:20 PM
robert_v's Avatar
what ecu are you running? if you are running a obd1 ecu on an obd2 car it aint going to work. all you see is error. but if you are running obd2 ecu then something is wrong with your car
Old Feb 6, 2006 | 06:00 AM
Default Re: cel problem (robert_v)
i forget the scanner, but i know the scanner isnt the problem, im running a type-r ecu obd2. something is wrong with my car as in take it to machanic or what
Old Feb 6, 2006 | 11:03 AM
bumpsky
Old Feb 6, 2006 | 12:23 PM
IHateJDM's Avatar
why are you running a type r ecu on a b16?
Old Feb 6, 2006 | 12:29 PM
CivicSiRX's Avatar
I would just check the cel the old fashion way. count the blinks and refer to the table. theres a how to top sticky of this forum that explains how to do it.
Old Feb 6, 2006 | 12:42 PM
Default Re: cel problem (CivicSiRX)
it says thats only for 92-95 civic
Old Feb 6, 2006 | 12:54 PM
CivicSiRX's Avatar
works for 96-00 civic as well.
Old Feb 6, 2006 | 12:57 PM
ok thanks, and does it still work with a diff ecu? i have a type-r
Old Feb 6, 2006 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">why are you running a type r ecu on a b16? </TD></TR></TABLE> cause thats what i bought it with
Old Feb 6, 2006 | 02:39 PM
CivicSiRX's Avatar
it will work fine.
Old Feb 6, 2006 | 02:44 PM
siflyby's Avatar
Default Re: (CivicSiRX)
can't do the blinky on 99-00 civic si! unless you've swapped it to obd I, really don't think it works 96 n up either.
Old Feb 7, 2006 | 09:46 PM
CivicSiRX's Avatar
Default Re: (siflyby)
it works. done it on my friends 00 civic dx with si changeover. works fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siflyby &raquo;</TD></TR><TR><TD CLASS="quote">can't do the blinky on 99-00 civic si! unless you've swapped it to obd I, really don't think it works 96 n up either.
Old Feb 7, 2006 | 09:53 PM
cambopheonix56's Avatar
Sure can. Ive done it plenty of times. Works fine on 96-00.
FlatBrokeHatch
Aug 30, 2007 06:21 AM
b20izzle
Mar 4, 2006 07:09 PM
crxhybrid85
Mar 5, 2005 06:45 AM
conesmasher
Oct 19, 2004 03:26 PM
