Honda S2000 Honda S2000
s2000 EPS in project car
Old Feb 4, 2006 | 10:36 PM
rcodea's Avatar
Default s2000 EPS in project car
Hello all, I was hoping to get some info from the maters. I hope you guys can help me!
Ok, I am trying to use the EPS system in a project car of mine. I have it all mounted, ready for the wiring. Since I am not using the f20 motor or tranny, I need some help with deciding what to use for the EPS computer inputs. Based on the factory wiring diagram I have, the following are all inputs:
1)B+ constant
2)B+ IG1
3)speedometer signal from gauge assembly
4)tach signal from ECM
5)"EPS load detect" from ECM, speed signal maybe?
6)3 wires for torque sensor
From what I have read, the system only uses the torque signal and the speed signal to operate the EPS. With that said, why would they have 2 inputs for the speed, and a tach signal? Which of these am I going to have to simulate?
My question is that since I am not using the ECM, speed, and tach signals, is it possible to "fool" the system into working properly? Is there a way to wire it all up so that I can get the powersteering to work without those signals? If I really do need a speed signal, would a 12V with a rheostat to change the voltage simulate it for a specific speed, then just adjust it as I need?
Any other ideas to make this thing work would be greatly appreciated. There has to be a way to get this wiring worked out so that I can use it.
Thanks guys
Ryan
Old Jan 12, 2007 | 07:36 PM
dwolsten's Avatar
Default Re: s2000 EPS in project car (rcodea)
I just found this with a search.
Did you ever make any progress on this project?
It seems to me you should be able to route the speedometer and tach signals without much trouble. These are both pulsetrains, so a rheostat wouldn't work anyway. The "EPS load detect" signal would have to be simulated, however, so you'd need some specs on what kind of signal is expected there.
xalents23
Jun 3, 2008 07:59 PM
vwtuner
Oct 1, 2005 05:38 PM
megadeath
Honda S2000
Jun 11, 2005 06:37 PM
tzenisj
Jul 3, 2004 01:45 AM
