oil pump removel help
Old Feb 4, 2006 | 04:37 PM
ej1_lsvtec's Avatar
Default oil pump removel help
i need a diagram on how to remove the oil pump from my ls/vtec. every thimg is out except the pully any help would be appriciated . thaks
Old Feb 4, 2006 | 04:44 PM
PLAN:B's Avatar
Default Re: oil pump removel help (ej1_lsvtec)
well you have to take the pulley's off (timing and crank), and oil pan, and anything else in the way. then all you do is remove the bolts holding it on and use a rubber mallet to tap it off (hondabond holds it tight)
Old Feb 4, 2006 | 04:47 PM
ej1_lsvtec's Avatar
Default Re: oil pump removel help (PLANBmotorsports)
thanks. I removed the big pully i need to know how to remove the small pully the one that drives the timing belt. do i need a pully puller?
Old Feb 4, 2006 | 05:38 PM
PLAN:B's Avatar
well i have never had to use a pulley tool...mine always just came off with a little coaxing ...pulling evenly on both sides. just make sure you use the right tool for the right job. if it doesnt just come off, go rent a pulley tool.
Old Feb 4, 2006 | 05:54 PM
ej1_lsvtec's Avatar
the one that im having a hard time with is the one that drives the timing belt. its on there preaty good.
Old Feb 4, 2006 | 06:20 PM
ej1_lsvtec's Avatar
Old Feb 4, 2006 | 06:55 PM
ej1_lsvtec's Avatar
bump cuz i want to finish tonight
rrmaron
Dec 4, 2011 11:54 PM
lsvtecturbonj
May 15, 2011 05:31 PM
thechamp657
Oct 6, 2007 12:18 PM
specscow
Mar 20, 2006 06:42 AM
4drsedaneg
Jul 15, 2004 06:00 PM
