Mini-me problems/questions
Old Feb 4, 2006 | 04:18 PM
littlej72's Avatar
Default Mini-me problems/questions
I have a 95 dx engine with a z6 head on it, I have been driving it for some time. I am using a z6 dist. (not that it matters). My question is why are you supposed to remove the jet that is at the back of the block between 2-3 (cyl) and wouldnt you get a Check eng. lt. if you left it in during the head swap? I have no codes but some other issues that I am starting to check into. Would an oil preassure check at the vtec psi switch show wheter or not it is in there, I dont remember if I took it out or not, i dont remember! I have tools and knowledge to check all this crap, just wondering what you think? Vehicle fails emmisions high on HC just marginally for some unknown reason? maybe the valve timing with this swap dosnt match up just right.... i dunno.
Old Feb 4, 2006 | 07:04 PM
97spooncivic's Avatar
Default Re: Mini-me problems/questions (littlej72)
you are supposed to take it out.
valve lash?
Old Feb 4, 2006 | 08:19 PM
scorpnaz7's Avatar
Default Re: Mini-me problems/questions (97spooncivic)
You have to take that out or else your vtec wouldnt work
Old Feb 4, 2006 | 08:28 PM
s13browe's Avatar
for those hc readings for emissions I went to firestone tire store and they have a fuel system tune up. that they do they clean your throttle plate put injector cleaner in gas tank and run a intake cleaner through intake vacum like an IV that cleanse plenum and valves out. that droped my hydrocarbons down from 375 to 122. in my gsr eg. it should drop yours lower than that...
hc is just unburnt gas pretty much so dirty valves would leak fuel out exhaust...
Old Feb 4, 2006 | 09:20 PM
Default Re: Mini-me problems/questions (s13browe)
how much did they charge you for that?
Old Feb 4, 2006 | 09:27 PM
s13browe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">how much did they charge you for that?</TD></TR></TABLE>
honestly I used to work there so the lead tech just did it for me shouldn't be too much though it really does work.
Old Feb 5, 2006 | 11:05 AM
littlej72's Avatar
I am an acura tech, so yeah induction service comes to mind, I have a feeling its more than that, although that is an easy thing to try and no biggie. I was more wondering if the swap inherintly has emmisions problems, and as far as vtec working, I was just looking for short cuts to see, I can do an oil prs test and see if it jacks up under load....hrmn
Old Feb 5, 2006 | 02:09 PM
kos99ngel's Avatar
I am looking to do a d16z6 swap also in my stock d15b7 civic 92 hatchback.
How much did you do you're swap for what did you used?
Anyone know what else am i going to need besides the d16z6 head to complete the mini-me swap?
Hey did you notice any HP gain?
Old Feb 5, 2006 | 07:59 PM
littlej72's Avatar
Default Re: Mini-me problems/questions (kos99ngel)
Im not sure initially what your question is, but you need a head, distributor, wires, plugs, head gasket, possibly intake gasket, t-belt, probably some other bs stuff too, oh yeah, apparently dont forget to remove the oil jet in the block....
Old Feb 6, 2006 | 05:05 AM
92hatchling's Avatar
Default Re: (HELLAnorcal)
yes the jet has to come out and the timing will be off a half tooth or something like that a adjustable cam gear will fix that im also having problems with the car bogging down in low rpm's and yesterday it started to spit and spudder real bad for a few secnds while in low rpm range any help on my isseus
Old Feb 6, 2006 | 06:19 AM
BauleyCivic's Avatar
Risky Business
Default Re: (92MiniMeHatch)
If you leave the oil jet in, the CEL won't come on.
https://honda-tech.com/zerothread?id=554053
matt2775
11
Jan 2, 2014 09:08 PM
psychodta
Apr 2, 2013 04:27 PM
rollinhonda3
12
Nov 11, 2010 02:48 PM
Garcia505
Jul 16, 2010 12:03 AM
egvtec
Dec 8, 2008 06:01 PM
