gauge cluster light doesn't work?? help me!
Old Feb 4, 2006 | 01:03 AM
97_delsol_Vtec's Avatar
Default gauge cluster light doesn't work?? help me!
i think i was messing with my wires..isntalling a boost gauge light...and so im guess one of my fuses blew out..theres nothing wrong with the bulb because when i autostart my car...the gauge blinks up and so does my side markers and corners...when i start my car and drive off...the cluster light turns off..and so does my corner and side markers...checked the fuse..nothing wrong but imma check again tomorrow morning...could anyone help me out? i would greatly appreciate it
Old Feb 4, 2006 | 01:10 AM
eg8000rpm's Avatar
Default Re: gauge cluster light doesn't work?? help me! (97_delsol_Vtec)
I hate electrical wiring problems...
Well if you did all the wiring yourself check the wires coming from the boost gauge and make sure they arent touching anywhere causing a short, check make sure battery cables are tight, and also check all of your ground wires to make sure they aren't loose and grounded properly.
I dont think it's a blown fuse otherwise the lights wouldn't even come on at all.
Hope this helps and you figure the problem out dude
ltran82
Nov 1, 2007 12:58 PM
MBlake55
May 25, 2006 06:24 PM
jdmilf
12
Jun 2, 2005 03:26 PM
rexnation
Jul 14, 2004 03:08 PM
cpforyou
Nov 10, 2003 07:44 AM
