How to hook up vtec
Old Feb 3, 2006 | 10:28 PM
StreetHuff's Avatar
Default How to hook up vtec
i have a 91 accord and i want to put a 95 sohc vtec in it. I need to know what what wires go where for the vtec to work.what pins do i need to change are add.
Old Feb 3, 2006 | 10:48 PM
accord95vtec's Avatar
HT White Ops
Default Re: How to hook up vtec (StreetHuff)
Is this what you are looking for? Search the CB7tuner website for help as well.
http://www.cb7tuner.com/vbb/sh...=5423
Pin locations for OBD-1 ECU’s:
- Vtec solenoid: Pin A4
- Vtec pressure switch: Pin D6
- Knock sensor: Pin D3
- Secondary Intake Solenoid: Pin A17 (Connect Black/Yellow wire on solenoid to switched ignition, the other to pin A17)
- FPR Solenoid: Pin A10 (Connect Black/Yellow on solenoid to switched ignition, the other to pin A10. This Solenoid is not found on all H22’s but it is on some. It will not hurt anything if you don’t use it, but should you want to this is the correct way to connect it. It is located near the fuel rail next to the IAC on the H22)
* Using a 94/95 Accord ECU (P0A/P0B)? Swap pin A6 with A11 on the ECU harness. This is necessary since the 5th gen was wired opposite of the 4th gen for these two pins.
And....there is another thread currently discussing what you need
https://honda-tech.com/zerothread?id=1513448
Old Feb 4, 2006 | 12:17 AM
StreetHuff's Avatar
Default Re: How to hook up vtec (accord95vtec)
Thanks alot man, You would't happen to know if i have to change axles and trans, whould you.
Old Feb 4, 2006 | 07:27 AM
Stew Pidasso's Avatar
Same trans and axles should work fine
Old Feb 4, 2006 | 01:16 PM
StreetHuff's Avatar
Default Re: How to hook up vtec (Stew Pidasso)
so my stock trans and axles will work, thanks alot man.
Old Feb 5, 2006 | 02:07 PM
StreetHuff's Avatar
how bout my motor mounts do i have to change them or us the 95's
Old Feb 5, 2006 | 02:41 PM
HT White Ops
I believe that you can keep your motor mounts the same; just re-use your car's mounts. Even with H22 swaps, you can re-use the accord mounts.
Old Feb 6, 2006 | 01:52 AM
AccordRacing's Avatar
USe your OEM mounts, tranny, axels, shift linkage, ect ..
fryman
Sep 24, 2008 10:07 AM
wernhersey
Apr 19, 2006 10:09 PM
1sikhatch
Feb 2, 2006 01:40 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
