B18b1 Into 96 Civic Dx
Sorry for the missunderstanding...
Im trying to wire a B18b1 Into a 96 Civic using a automatic d16y8 wiring harness... and the automatic harness, i can seem to find the plug. for the TPS
Modified by Novtecdohc at 6:32 AM 2/4/2006
From: University of Massachusetts, Amherst, Ma, US of A
um, tps sensor should be on the throttle body, and only one plus will match, and well your problem could be that the b and d series tps might be totally different. Also a d series intake mani on a b series, WHAT?
The TPS connector is a 3 pin plug with a red wire in the center. The other 3 pin plug that is in about the same place on the harness is for the MAP sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB18bCivic »</TD></TR><TR><TD CLASS="quote">Also a d series intake mani on a b series, WHAT?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Novtecdohc »</TD></TR><TR><TD CLASS="quote">Sorry for the missunderstanding...
Modified by Novtecdohc at 6:32 AM 2/4/2006</TD></TR></TABLE>
ok again, I don't believe it will work, you're taking a VTEC wiring harness with a non vtec car, its possible, vtec doesnt have to be wired up, but then you have the fact that the AUTOMATIC wires are totally different from the manual tranny wires.
save yourself some time and money and buy my b18b1 wiring harness off me, some is spliced but would be easy to rewire, 40 bucks and you can have it and enjoy not dicking with the automatic d series wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB18bCivic »</TD></TR><TR><TD CLASS="quote">save yourself some time and money and buy my b18b1 wiring harness off me, some is spliced but would be easy to rewire, 40 bucks and you can have it and enjoy not dicking with the automatic d series wiring</TD></TR></TABLE>
That isn't really a good option, the OBDII Civic wiring harness is one piece all the way back to the ECU. The Integra harness is two pieces (all those connectors on your passenger side shock tower). It would be way easier to use the stock harness that came in the car then to change everything over.
Vrivera
Apr 20, 2018 03:07 PM
zach2004t
Jul 19, 2010 04:40 PM
91-hatcherz
Dec 20, 2009 01:02 PM
Quad-Damag
May 19, 2004 11:05 AM
