Charcoal Canister removal.
Old Feb 3, 2006 | 08:22 PM
www.megameet.org's Avatar
Default Charcoal Canister removal.
So, Can I do it, and is there anything I need to know. I am useing a p28 obd1 ecu with hondata.
Will unplugging the wireing do anything? I have a 98 dx coupe shell.
Modified by www.megameet.org at 10:03 PM 2/3/2006
Old Feb 4, 2006 | 05:27 AM
Default Re: Charcoal Canister removal. (www.megameet.org)
Anybody know about the romaval of this?
Old Feb 4, 2006 | 06:03 AM
92civichatch1's Avatar
its not really causing any problems. Its there for emissions purposes. It takes all the hydrocarbons from the gastank and instead of putting it in the air it goes back to the intake mani.
Old Feb 4, 2006 | 12:11 PM
Default Re: Charcoal Canister removal. (92civichatch1)
I understand how it works. Has anyone done it. I drove to work with it unplugged today and no cels, so I'm sure I'm going to be fine. I am putting a catch can in it's spot.
Old Feb 4, 2006 | 12:46 PM
SkankyEJ7's Avatar
i just removed and cut off the plug
Old Feb 4, 2006 | 02:07 PM
Default Re: Charcoal Canister removal. (98ekhx)
Cool. Hey does anybody know, I have like 6 plugs in my engine harness i'm not useing, can I just cut those off as well to clean stuff up a bit? They have been their as clutter for like 5+ years.
Old Feb 4, 2006 | 03:20 PM
brusk13's Avatar
I wouldn't cut them. I would pop the connectors off saving the pins and then shrink wrap them and tape them back into the wiring harness. People never think about the future of swaps, selling there car or the harness when there done.
Old Feb 6, 2006 | 06:42 AM
Default Re: (brusk13)
thanks for the heads up.
Old Feb 6, 2006 | 07:18 AM
the soL that could's Avatar
there's really no point in removing this... it's not going to increase HP, just save a couple ounces of weight. if it really matters and you're a 9 second car, more power to you. otherwise, your **** going to smell like gasoline.
Old Feb 6, 2006 | 07:32 AM
Default Re: (the soL that could)
exactly the point i was trying to make above. There is NO HP increase there is no added torque. Theres nothing good coming from this. If anything its bad. U will fail inspection. Your gonna smell gasoline. You also run a risk of fire. Your decision to do this is a bad one.
Old Feb 6, 2006 | 07:37 AM
Luserkid's Avatar
Default Re: (92civichatch1)
If you do it then go under your car following the line that puts the vapers back and cut it there. If you dont then your engine bay is going to smell really bad.
Old Feb 6, 2006 | 07:54 AM
zuich2ID's Avatar
well since everyone is talking about the gas smell...how come every now and then in my 94 talon DL....(sad i know) i smell gas when i drive? is it dirty or plugged injectors or fuel filter or wat? PM or email me with answers...sorry to steal thread...thanks
Old Feb 6, 2006 | 08:14 AM
Default Re: (piccilo2)
There is no gas smell. I have had one hose from the canister disconected since my swap 6 years ago. No problems. Still no problems now. I put a catch can in it's location, that was the purpose of this. The idea was NOT a bad one. I know quite a few people that have this done, (race cars, in street classes and above) but they did it such a long time ago...I thought I would ask.
I actually did the thread because there isn't much covered on it here, and I was interested in what everyone would say. I guess kind of testing the knowledge a bit. I havent been on this site in so long, I wanted to see how it was now on a relatively easy question. Past simple bolt on questions is where you really find out the knowledge of someone I think. Not that this is one of those situations.
I am not trying to be rude at all, but just wanted to see the experience of some members and maybe get some new insight. Thanks to everyone who posted!
BTW piccilo, you didnt steal anything. I think it's good to add the info on here, since the gas issue is where this has leaded. We should cover all "gas smelling' issues here also so that maybe something can be rulled out, or so we can prove that maybe the smell doesnt apply to the charcoal canister idea at all.
Old Feb 6, 2006 | 08:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (www.megameet.org)
I just have the line open. No canister or anything. Whatever.
Old Feb 6, 2006 | 08:17 AM
Default Re: (JDM_Ej)
I think without topping off the gas during fill up, your doing just fine, right?
Old Feb 13, 2006 | 01:21 AM
bch5428's Avatar
what the other hoses that run off the top of the canister?
speficially, the "dashpot control solenoid valve"
i dont wanna leave random hoses unplugged, and id like to find out specfically what each one is for. i got an EF though, i dont know if it makes a difference.
sorry to bring this one back alive.
Old Feb 17, 2006 | 09:29 AM
Sean Juan's Avatar
Default Re: (bch5428)
I removed mine. I'll be cutting the line for the vent in a few mins when I get my car on the lift. No problems at all, and it helped the engine bay look cleaner.
Old Feb 18, 2006 | 05:42 AM
Default Re: (Grip King)
same her. I didnt cut any lines though. Just unplugged. I left the thing under the battery there.
Old Feb 18, 2006 | 08:45 AM
j_fukin_t's Avatar
i wish i could just get rid of mine, but i'm obd2 and it will throw a CEL in a second once it starts running, only reason why is because i'm getting sick of the guessing game of which part is bad and which isn't i've replace like 3 things on the whole evap system and it still give a gas fume smell
egb16pg
Mar 24, 2007 09:58 PM
polymath
Jun 19, 2006 03:22 PM
FerioVtec94
Sep 10, 2003 07:39 PM
sCeRaXn
Oct 13, 2002 03:08 PM
CRAYZBOYZS
Jul 18, 2002 12:55 PM
